Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 25 Guests are viewing this topic.
WaveWatcher
Sorry no input lately. Have my earlier project knocking my socks off right now. Research the effects from it I am finding direct relationships to SM stuff. Please take a gander at my attachments. Not supposed to be online right now.
I am convinced the amp goes in the middle because of time dilation and the coil is Mobius in a coaxial or waveguide construction. 180 degree seems to refer to phase angle not position or quantity of coils. The signal source is earth's core. The SM coil and my contraption are simply Farady pickup coils.
Loop antennas provide multiple gains at higher than designed resonance at almost random points of the spectrum. I am convinced his coils were flat tubing, waveguides or coaxial and Mobius.
Am I sounding weird? You would be too.
More later.
I am convinced THIS IS NO FAKE. Since mine knocked me flat last night - after it was disconnected I don't think mine is either (no caps no controller!). Maybe I've just gone nuts. I'll sleep on it.
WaveWatcher
forgot this one - and there are plenty others out there. Most done after SM work.
IronHead
Congratulations you are still alive WaveWatcher and you might be crazy but you are not wrong.
IronHead
Bruce_TPU
Quote from: WaveWatcher on June 19, 2007, 08:29:28 PM
More later.
Your ??? knocked you flat last night?  A TPU of your own design?  Otto's replication?  How did it "Knock you flat"?
You mentioned "time dilation".  How would you know that?  I mentioned that in my thread some time ago, but figured everyone thought I was crazy.  Why do you think this is so?  How did you wind your  coil and with what wire?
Sorry for so many questions, but we on this forum are all very tired of riddles.  :)  So details would be wonderful!  (I am sure you understand!)
Hmm... I think SM's device has interaction with 7.23 HZ, but I do not believe it is an Antenna in the clearest sense of the word.  It is similar to what Otto is doing.  But I do believe there is more to it.
Warm regards,
Bruce
devilzangel
ok guys ..
ATTACHED is a PNG file that has SCREENSHOTS of the 15" TPU, the preliminary TPU, and the open black TPU from SM's Videos.
link to post: http://www.overunity.com/index.php/topic,2285.msg36145.html#msg36145
The Image file is 3.79MB in size. I tried to keep it as high quality as possible + PNG format
one thing i find important to note is that i see FOUR coils in the open black TPU .. 2 thick wire windings, and 2 fine wire windings. (they might ALL be the same thickness, though hard to tell).. i have added notes in the images as well.
EDIT: ANOTHER point as WAVEWATCHER says .. the WIRES are FLAT and horizontal parallel in the 15" crosssection cutout.
devilzangel
