Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Bruce_TPU
@ WaveWatcher
I have read through both of your downloads.  Very impressive information.  Now I see how you came to the time dilation theory.  General relativistic electromagnetic effects explains it fairly well.
The other download CERTAINLY makes the case for Alternating current being used in the control coils rather than Direct Current.  I too have said this for some time now, and I am convinced that this is what SM did.  But your download give the scientific reason "why" I do believe.
As far as winding the collectors as an antenna, I and my researchers had thought of that but then had set that idea aside.  So, in your theory of operation, we have collectors with mobius, wound as an antenna, tuned to resonate.  Alternating Current for the input to control coils, and then the frequencies to bring resonance = electrical power output.  And "tuning" the Alternating Current to the core (7.23 Hz) would be best.  Is this your thoughts?  (It sure sounds alot like mine! LOL)
Thank you for your time,
Bruce
giantkiller
Quote from: devilzangel on June 19, 2007, 09:48:00 PM
ok guys ..
ATTACHED is a PNG file that has SCREENSHOTS of the 15" TPU, the preliminary TPU, and the open black TPU from SM's Videos.
link to post: http://www.overunity.com/index.php/topic,2285.msg36145.html#msg36145
The Image file is 3.79MB in size. I tried to keep it as high quality as possible + PNG format
one thing i find important to note is that i see FOUR coils in the open black TPU .. 2 thick wire windings, and 2 fine wire windings. (they might ALL be the same thickness, though hard to tell).. i have added notes in the images as well.
EDIT: ANOTHER point as WAVEWATCHER says .. the WIRES are FLAT and horizontal parallel in the 15" crosssection cutout.
I have also uploaded the same image file to ImageShack (i dont know what the fetch limit is on imageshack, so this link might stop showing after some of u DL from there)
devilzangel
Contact Stefan and post this on OU for download. Or give us a work around for image shack. We shouldnt downloading a toolbar buddy/loader.
Thank you. giantkiller.
Motorcoach1
@ WaveWatcher - Very Interesting , this is inline with my copper tube and coaix bradeing. I know this is ottos thread so i"ll post in your thread, tomarrow, it's late I'm tired . Mike  and thanks you for the post
WaveWatcher
Ok. I?ll take a break for some background. Yes, I can be full of it but I am an experimenter in many things, especially if the ?Laws? say it can?t be done.
No, I?m not SM. I?m a longtime HAM, currently an EE and formerly titled ?wave propagation specialist? and  ?data analyst? when I was doing SIGINT for Big Daddy DIRNSA. (In GOD we trust, all others we monitor!). I worked in some of the same stations as Ed Dames (now there is a nut! Spoon benders?)
I wiped out AM reception for two blocks when I was 10. And I had an NSA ARPA handle before any of you heard of what became the Internet.
Enough.
For months I have been working on the magnetic equivalent of what is commonly known as a pilot valve. A simple device to use a very weak force to control a much stronger force. Like you can use a few inches of vacuum to control thousands of pounds of pressure. Allen Bradley uses an electromagnetic equivalent in many of their air circuit breakers. It is two plain solenoid coils at opposite ends of a cylinder. You energize one and the plunger is pulled to the coil ? and the reverse ? after removing power from the other coil. In the middle is a bearing for the plunger that is actually made of PMs with North all facing center. When the plunger is at either end it completes and maintains the magnetic circuit. The circuit complete the attraction locks the plunger in-place (against 10s of pounds of reverse force!) The coil on that end has no power. Apply power to the opposite coil and it sucks the plunger to it completing that magnetic circuit and breaking the other. All with a DC signal and only a few milliamps and simply by ?redirecting the magnetic flux away from the previous completed flux circuit.
I think ? why can?t I do that and use the resultant electrical energy instead of moving a plunger? Forget OU. I just want to see if I can do it. One thing ran into another and I tied the pulse from one coil to another with some LC (no, not big enough mFd to hold a shock) to phase it so it is useful and next thing I know I have two small hacked RS transformers with PM inserted linked as one howling, audibly,  about 300hZ with no signal applied.
Yes, I know how it is with wannabe?s and skeptics (and wives too!). I feel your pain. But continue ? be thorough ? use scientific rigor ? try to understand what is going on ? do research ? BE SAFE! It was my research that led me to you. I?m an opensource kinda guy also. But it will work every time and be useful before I put someone else through this hell.
I want to be helpful but one thing at a time. What I do believe is this:
Earth?s core frequency has dropped a bit since SM.
It isn?t possible for most of us to build a resonant loop at the base freq. Hence the pickup coil ? just what is needed when trying to collect energy from a signal generator operating at much lower frequency that the resonant freq of the pick-up loop.
The frequency ratios are most likely 1-4-7 (as in mine) or multiples of those numbers.
You have to find 7 first and look for a 1 and 4 that ?series aid? when they sync.
Your frequencies will vary between projects AND physical association with magnetic and non-magnetic mass near the coils.
The whole thing is probably a never ending Mobius electron-gun.
Rotating around the ring each pulse ?squeezes the water hose? at just the right time to accelerate the paired electrons to the next ?squeeze point?. The ?squeeze? must happen just behind the electron pair and not on top of it (boom).
Magnets are to a massive flux field as a lens is to light.
The SM coils appear real. Yes mine is unique but much of the same work must be done by the experimenter and the device to get the results.
Things have probably changed since I worked for ?The Company?, they didn?t give a hoot what folks did ? but all of it was recorded and filed for future reference. Until I?m sure I?m not nuts, can document, calculate, explain, reproduce and broadcast the final details through multiple channels, I?m not posting enough detail to be discredited by folks that use math that can?t prove itself and think any line exists beyond an arc.
My device exhibits many of the SM reported properties as the SM coil and the tests performed on my earlier attached docs, even after the A.C. is removed.
Some say there are two kinds of people ? Those who understand thermodynamics and those who do not. I agree.
Until I can give you enough documented detail to replicate my results I?ll post only when I really believe my information is useful ? as I?m sure you all would wish ? as I would wish.
I apologize for my exuberance before.
WaveWatcher
If I am understang the SM device correctly - DC pulses would be correct as you must temporarily dislodge/expand the Earth's flux to create movement of that flux. The collapse of your flux, along with the Earth's, when your signal goes zer0, is probably what is squeezing the water hose.
Movement of the earth's field would be a good thing for this coil.
Stick with the info you've learned from SM and the other's here. Don't change direct abrubtly as my device is a different animal.
