Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Bruce_TPU
@ WaveWatcher
I am very glad to have you on our board.  I think that you have much to bring to our TPU table.  I do agree about not changing direction.  BUT  ;) with that said, there are always avenues of experimentation that can be easily done, especially by some of our more skilled members.  So, I would suggest, as time progress's any future ideas for experimentation with our ECD be posted, and someone, I am sure, will oblige.
The AC will be important when the time comes.  the "1-4-7" explains alot, and someone hit on it earlier.
Working backwards:  (sound familiar? :) )
7 - 249.93 KHz
4 - 142.82 KHz
1 - 35.705 KHz
I have more thoughts but for another day.  But this we can experiment with now!! :)
Thank you for your time,
Bruce
Motorcoach1
WaveWatcher Thats to funny. I'm working on 2 coils face to face with a small magnet in the center and one at each end of the coils NS (Bismuth) < SN (Center Neo) > NS (Bismuth), when the coils energize the oscillation starts - vary the current the oscillation changes as fro the feed back circuit or how you may want to incorporate it in the system. Mike
Grumpy
Tesla found that the charged particles that collected in his single-wire globe would rotate clockwise due to the Earth's mazgnetic field - this implies a magnetic field that is perpendicular to the earth - not north-south.
Notice CW is in the northern hemisphere - like SM's ring.  I guess that Marinov's MAGVID also rotates this way.  Perhaps it rotates faster one way than the other - one would increase the other subtract - again Russell is correct.
This is in-line with the true depiction of the earth's magnetic field in which the vortices that are known as the "lines of force" are perpendicular to the surface and the earth is not a single magnet, but two - Walter Russell also showed this fact - how very cleverly the universe is constructed...as it must be.
Would you not create a current if you created a rotating magnetic field in the presence of a conductor? - CW in northern hemisphere - CCW in southern.  Notice how the forced rotating magnetic field "rolls" as it rotates - with the same loops as drift current.
The toroidal overwrap that SM used on later versions, what could be it's significance? Perhaps it does not radiate, or would it not receive?
        -Frank Edwards
c0mster
2 Tests tonight....
Can my triple step-up coil (Tesla Style) newman motor light a bulb on one coil?
Can the magnet bar be made to move with the addition of dc in one other coil. (as per doc posted earlier)?
Results , Yes and Yes, when 9V was applied to the upper coil the magnetic field disappeared in the device and the bar rotated freely by hand. There was no change in the output of the light.
Cam
z_p_e
For anyone that might be interested, I've reduced Otto's and Roberto's circuit down to a more simple representation.
You'll notice that the input is analogous to an OR gate, but in the real circuit (the previous one I posted) battery current draw increases as more HI's are present on the inputs at the same time.
I've been trying to understand why Cam's experiment showed a significant decrease in output power when the 3rd frequency was introduced. I believe the reason might be because the frequencies are not synchronized.
Random switching will only cause the spikes to coincide occassionally, and when they are not "in sync", the primaries could be "ON" for a significant portion of the time (wasting power), and yet the benefit of this ON time is not reflected in the output.
I highly recommend that all build a harmonic divider (i.e. fundamental, 2nd and 3rd harmonics) and use that to feed your FETs.
Regards,
Darren
