Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
weri812
TO ALL
HERE ARE THE PICTURES IN PDF FORM
WER
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
chrisC
Darren:
I totally agree with your analysis, especially the need for synchronization of the harmonics or at least some precision control of the wired OR common path. Did SM not say that there is a requirement of quality engineering equipment to be able to perform enginerring analysis? Maybe I mis-read that but I somehow remmebered the need for good tools.
chrisC
WaveWatcher
Suggestion:
The 7 freq should be the resonant freq of the small coil. This one would be more broadbanded and also work at the freq of the larger coil.
The 4 freq should be the resonant freq of the larger coil. This one would be most critical with high Q requirement. I could understand if this one needed to be tuned.
The 1 freq would be a harmonic of our biggest common generator (Earth).
Using other than air core on a toroid should just allow you to work closer to the base frequency (larger signal?) while keeping the size managable.
On the later SM units he was probably able to provide more 'sqeezes' with a single outside winding since he then knew the frequency and therefore was able to calculate exact winding spacing and wire size. With proper design he could get the odd turns and even turns squeezing in an alternating fashion. 3rd harmonic pulsing 120, 4th pulsing 90 or even faster? This is starting to sound like a rail-gun.
Thaelin
   Number 1 (35k) rolls in right at the place whistlers are the strongest.
   So this puts us at small coils at 245, big coil at 140 and the derived at 35k.  Hmmmmm
sugra
mrd10
Quote from: c0mster on June 20, 2007, 12:12:47 AM
2 Tests tonight....
Can my triple step-up coil (Tesla Style) newman motor light a bulb on one coil?
Can the magnet bar be made to move with the addition of dc in one other coil. (as per doc posted earlier)?
Results , Yes and Yes, when 9V was applied to the upper coil the magnetic field disappeared in the device and the bar rotated freely by hand. There was no change in the output of the light.
Cam
Cam, nice work there mate, can't wait to get more juicy details.
Dom
