Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 36 Guests are viewing this topic.
kokomoj0
Quote from: chrisC on June 12, 2007, 12:22:57 PM
@kokomoj0
Anyway, welcome to the 'believers- club'! Membership is free. The only other requirement is to free your mind of previously conceived or previously taught orthodox ideas of how things can and must be done!
Peace
chrisC
WOAH thar!!!!
Not quite yet am i a believer.   several posts back i requested that they run th eoutput through a DC bridge and filter with smoothing caps to provide a filtered DC output.   Then put a load on it with whatever they feel it can do using the filtered DC output.
Remember meters have rms algorithms and can be fooled by non-sinusodial signals.   i am not saying that it does not work but the only way to really show it is with a filtered output loaded up to show beyond any doubt this in fact is doing everything expected.
So i am almost a believer but not till i see the results of a test as i havc described here.
Bruce_TPU
@ Kokomojo and others
I am a NON electronic guy who spent about $18.00 to replicate Otto's work.  It took about 30 minutes to build the collectors and tonight I post some pics.
So my point is this.  Just spend a few bucks, wind the coil and help us out.  Test it, retest it, experiment with it, post it.  You guys have all of this knowledge and experience, so just BUILD IT!  ;)
No excuses, or reasons, just build it, and post.  Pretty simple.. LOL
I do encourage you all in a friendly way!
Cheers,
Bruce
jacob
Quote from: ronotte on June 12, 2007, 06:40:40 AM
@Jacob,
I have had time only now to read your post.
I've no words: T H A N K
and best luck to the many guys who are now succesfully replicating ECD.
SORRY TO SAY but remember: ECD IS REALLY DANGEROUS...never forget it
Sincerely
Roberto
Anytime Roberto! We're all here for the same reason: we want this to succeed. So it's important that we stick together.
Regards,
Jacob
dani1
EMdevices had posted a video in the pulsers only thread. This may be a way to control the output of the ECD by distore the input frequencies with magnets and coils.
http://www.overunity.com/index.php/topic,1825.msg34190.html#msg34190
Do you know what i mean?
steve_whiss
Hi all,
another silly Q and then comment about use of FETs as switches.
Q: in the rig with a single DC powered coil - would this not work with magnets substituted? That would be definitive proof of "no power in".
Suggest a group of 3 or 4 magnets be taped about the coil , same pole to each end (they won't like that).
OK, FET's.
Was involved with switch mode PSU many years ago and we found that using FETs gave massive noise / spikes / RF, whereas using HV silicon trannies as used in EHT circuitry did not.
How much are those spikes needed & part of the system, how much are they an unwanted by-product?
Suggest looking up whatever transistors other then MOSFETs etc are nowadays used in HV generators (TV sets) / switch mode PSU and seeing if there are bipolar silicon ones.
For a circuit like this I don't think you need anything particularly fast, just able to cope with HV spikes.
Bipolars tend to run hotter though.
Steve
