Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
bob.rennips
Quote from: z_p_e on June 29, 2007, 12:02:25 AM
...This is what he (SM) says exactly:
QuoteThe first frequency, then second harmonic component into the second, then the third.
How do you interpret the above? ...
Thanks,
Darren
It could be read as:
"The first frequency, then second harmonic component into the second, then the third frequency"
OR
"The first frequency, then second harmonic component into the second, then the third harmonic"
If he meant the first, then he could have been cryptically refering to using octaves.
e.g. 220, 440, 880
440 IS the second harmonic but 880 is 3rd Octave (or 4th harmonic).
Jdo300
Quote from: sugra on June 27, 2007, 05:53:02 AM
@ Jason:
   This is actually not really related here but then it is. I am so taken with the scope that you have in the background that I would love to know who makes it and the specific model number. I am in the market for a new one and want a good one to boot. Thanks
sugra
Hi Sugra,
I bought the scope off eBay from a company in China called OWON. It
s basically a Tektronix clone but it works great for my purposes. Giantkiller also bought the same model and it works great for him also.
They are always posting auctions on eBay for them. You'll get hits immediately if you type "owon" in as the search term. Here's a direct link to one of the auctions for the scope that I purchased:
http://cgi.ebay.com/New-Digital-Color-Oscilloscope-OWON-PDS5022S-w-USB_W0QQitemZ140133384807QQihZ004QQcategoryZ104247QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
God Bless,
Jason O
MeggerMan
Hi Jason,
I too have an Owon scope, PDS6062, that I got from the Owon distributor in the UK:
http://www.owon.co.uk/pds6062.asp
I would not recommend buying this off ebay as it comes with no warrentee. This is what Owon UK told me.
Its cheaper and safer to buy direct from a distributor in your own country if there is one.
Also upon request I got them to make the soft bag for it.
So they now have a black nylon soft bag to put the scope in to protect it. Its not on the website so you need to ask for it.
Rob
Bruce_TPU
Quote from: WaveWatcher on June 19, 2007, 08:29:28 PM
The signal source is earth's core. The SM coil and my contraption are simply Farady pickup coils.
Loop antennas provide multiple gains at higher than designed resonance at almost random points of the spectrum. I am convinced his coils were flat tubing, waveguides or coaxial and Mobius.
My reply to WaveWatcher was incorrect.  I did not understand what I realize as of tonight.  The TPU IS like an antenna, like a radio, in the sense we ARE Tuning the device to a specific frequency.  The magnetic field of the Earth.  But NOT to 7.8 Hz Shummans Resonance, it will destroy.  No, the TPU needs to be "tuned" to resonate at 7.2-7.3  tuned "just off" of the "frequency of power".  THIS is how it acts like a Magnetometer!  Everything else remains the same.[/color]
This IS how the magnetic field of the earth is responsible for "converting" the power.
This IS the meaning of a "weak magnetic field over 1000 wires".
This IS why it will not work upside down!  (Think of the spin of hurricanes and toilets in different hemispheres!)
Go South and it would have to be wired in reverse!
THIS not only solves, BUT is the TOTAL answer.  ADD this to what is being done and see the power. Take this and put it into all of the clues about the earths magnetic field.
Question: How do we make an "antenna" collectors "RESONATE" at 7.23 Hz?   ???
That answer will be the practical solution.
Quote from investors Email:
"It is supposedly tuned to the 7.23 Hz Earth's EM field.
It is shown in 3 sizes:  about 10 inches in diameter, larger, and the largest
one was about 18-24 inches in diameter.
They are placed flat (parallel to the ground) in the air (on a glass table)."
Quote from answering investors Email:
"The outer toroidal coil overheats and has no magic factors inside it other
than a length of the coil which is cut until resonance is established."
Video Quote of SM:
"It vibrates 7.3 times per second."
Lamp chord loop antenna with mobius, antenna tuned to 7.3 Hz.  Everything else we are doing the same.  ( You decide.  It is either an electromagnet of our making at 7.3 Hz or it is tuned to the resonance of 7.3 Hz)  Think magnetometer!
Happy, Happy Days!  :)
Bruce
ronotte
Hi Darren, Rob,
If it can easier our tought I tell you that what is really needed, for start, is just to use the 1st & 2nd harmonic for F2 and F3 and leave asynchronous the lower range (F1) as it must be played to move the Seed location. I did played yesterday evening in that way ...and OK.
I did it so: connected my Wavetek 288 synthesizer to a flip-flop and so obtained a synched F2 and F3. Then I used another oscillator (NE555) to supply the lower range F1 and tuning it with a 20 turn pot.
Darren, I've not jet reconnected the original ECD so be patience hope to do it today. I wonder if you could in some way to take in account the Mobius turn..at the end it is similar to a 1 turn coil so I could find a way to give you the L R and Q if not too outside my LCR meter range.
Rob, I ordered the DDS20 Kit I can't wait to get it!
Roberto
