Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Bruce_TPU
@ Darren
He is a youth.  And there is never a reason to be unkind.  (Well, hardly ever!  Kokomojo was perhaps an exception! LOL)
z_p_e
Quote from: btentzer on July 01, 2007, 12:36:01 AM
@ Darren
Bruce, sorry to appear harsh, but that affords me even more reason suggest he double check his measurements BEFORE MAKING ANY CLAIMS OF OU!
Unless of course he enjoys a good whipping.  :P
There's a great deal to be learned from what has been discussed here since Otto and Roberto made their claims regarding what NOT to do. I suggest you both go back and review it as thoroughly as you yourself have reviewed SM's material.
Darren
Bruce_TPU
@ Darren,
It would be sad if he has what he claims and to think that remarks like yours could make someone not even want to post.
Big deal if he is wrong, dude!  What have you lost??  A few minutes, and maybe an experiment?
EM Thought he had it and we were excited, but he didn't.  It is okay.  At least they are experimenting with real things...LOL
Bruce  ;D
z_p_e
Well, first of all Bruce , what would become of this thread and forum if every second day someone posted an IDI and they consistently turned out to be false claims?
Think about that dude. You heard of the story of the boy that cried wolf?
The point I am trying to make, and have tried to make several times, is DO YOUR HOMEWORK FIRST!
Trust me on this one, people don't like to be jostled around when it comes to claims other people are making. Eventually, if it continues, people won't respond at all, and when the real thing actually DOES arrive, THAT will be sad, because it will be ignored. Get it?
You ask what is the big deal if the claim is false?
Then I ask you this...What is the big deal of doing your homework first?
If I tell you I can drive a 100Watts into a loudspeaker using only a LM324 Opamp output, are you going to take my word for it and start building it? Or would you want to see proof first?
Cheers,
Darren
HumblePie
First post, Does this thing still need to be umbilicaled to dds/power suppply or not after priming?  It it only needs priming and is then wireless, drive loads!  Is this like the MEG that likes non-linear ,loads only?.. like lamps?  Back to reading this thread on fire before I fall behind.  Thanks for answering in advance.
