Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Earl
Hi Roberto,
I see no reason to expect heterodyne by-products since there is no apparent non-linear element ( = mixer) in the TPU.
Do you see a non-linear element somewhere that I missed?
Regards, Earl
Quote from: ronotte on July 01, 2007, 05:24:39 PM
@Darren,
thanks for your simulation Darren, it seems that the peak frequency summation is really equal to reality. What I don't see is:
- by product of freqs heterodying
... could you try to just offset the freq values I gave You (like in actual operation...is difficult to centre the exact value) and see the effects?
[snip]
Roberto
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bruce_TPU
@ Stefan
I suggest upon successful replication of the brnbrade coil, it be moved BACK to this forum.  I concur completely with Rich in this matter.
Thank you,
Bruce  :)
HumblePie
Hey Y'all,  Pipes, tubes, plastic?  I'm still reading...from both ends.  Somone please tell me what Reply#'s talk about this.
Humble
Technoalchemist
Hi all. Great stuff you have here. Congrats. I too believe SM has it, as Tesla and Henry Moray before him. I have watched the videos, read the correspondences, and most of this posting here. I would like to make a few comments regarding SMs' words from the PDF on PESwiki and one video......He does mention earth resonant frequencies. (7.83Hz) He also speaks ALOT about Tesla, and his wacky TV story. I have been getting into "natural radio" (ELF) quite a bit lately. If I understand Schumann resonances and frequency harmonics at all, our "earth-resonant antenna" becomes 31.42' long @ 7.83MHz, or 314' @ 783KHz. I could be wrong. I have read that our 60Hz power system resonates with the Schumann cavity. I believe one of the coils acts as an antenna. Calculating toriod antennas may be different, but I know they are used for satellite. When he said to "never tune to exact frequencies of conversion" I suspected he meant this one. For it also appeared to me that the discord in the other frequencis is where the useable power comes from. The fact that the unit produces RF burns was another clue to me. The gyroscopic effect another. He also mentioned Tesla and "tuned magnetometers" His commentary could also be a bunch of B.S. too. Very good to see Bob Boyce here.
Now I have some questions:
1: Has anybody seen the UEC patents? I think the MPT are rubbish
2: Are you all in concensus that there is a battery in play here?
Its an honor to be here with such an astute group of folks, doing some of the greatest energy research for REAL public good in probably a century. Three words for the experimenters: SAFTEY, SAFTEY, SAFTEY! Don't cook yerself off with these great toys.
HumblePie
I did see him install a watch battery in a 6" unit on video a few years ago where he powered two 60W End-Table Lamps.  How much kick is really needed?  Can you reduce the drive frequency power levels as total conversion is neared or do you really need to start so high?  I'm still reading so I don't fry my face off by powering up in ignorance.
