Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
kosmoss
Hi, Everybody.
   I am new to this forum and I admire all of you and the hard work you put in the subject. I've been doing
research of OU devices for some time now and i when I came across this topic I was quite excited.
I would like to replicate TPU myself, but before investing time and money in a project, I do my homework.
   I have read all the essential messages in this topic and I must admit, my enthusiasm has faded. Why?
   After the first messages, I saw the video of Jason lighting the light bulb obviously. The power supply
shows 40V input or something after the bulb is fully lit. If the coil returned power to the power supply,
the voltage on the display should go down not up, it is just logical to me. My conclusion is, that the light
bulb was just powered from the power supply via transformer. You all saw what happened after connecting the coil to the battery.
   I was trying to find some info on Steven Mark. Some credentials, website, anything. I thought that the
man called "The Master of Magnetics" or his UEC Corporation should have a website. Nothing I could find. But found this, and you better take your time to read this just in case:  http://www.padrak.com/ine/SMARK.html
   Obviously, I watched the videos of SM devices on YouTube. This 38 min video is nicely done, ties, nice
house, furniture etc. But, it proves nothing. Inside the house, many trics can be done like induction,
hidden power cables, batteries, etc. I know what you will say: he took it outside! Right, but look carefully
at the camerawork at that moment; still inside the house camera loses the contact with the person who
carries the coil for a brief moment, just enough to switch it to battery pack. He goes outside, demonstrates
that the light bulb is lit. The same trick on the way back, you loose visual contact with the coil yet
again. It can be switched to anything. This video proves nothing.
   In another video SM demonstrates his device to some people. The date is 1997. If the coil is working,
what took him 10 years, just to make another video. It is just common sense, that somthing is not right
here.
   Did any of you see the device working with your own eyes, not on video? If even so, did you have a chance to test it properly, like running TV for 24 hours? Talk is cheap, seeing is beliving.
   Please don't understand me wrong, I am not writing this to undermine your efforts, I am just looking for
some answers.
   Best Regards,
      Kosmoss
chrisC
@kosmoss
Welcome to the SM TPU Research forum. Obviously you have not read far and wide nor deep enough. The stuff you posted is more than misleading.
Start with these condensed readings first.
1. http://www.overunity.com/index.php/topic,712.2560.html
from Darren (ZPE)
2. http://www.overunity.com/index.php/topic,2383.0.html
Stefan's - the webmaster of OU
3. Then when you understand enough, look at Otto's, Renotte's and follow Tao!
cheers
chrisC
Bruce_TPU
Oh brother!
Another Kokomojo.  He forever haunts the forum!  LOL
Mr. I did my homework, you mean well, I'm sure but...Back to your studies.  We have covered all of this many, many, many, times.  Please do a search of Kokomojo's old thread...LOL  You will save us all the time of writing the same things...again.
Cheers,
Bruce
otto
Hello all,
@Kosmoss
1. forget to find patents about the TPU
2. forget the padrak.com shit
3. forget that this videos are a fake
You want or dont want to work.
If yes, you are wellcome but I must warn you: its a veeery hard "job".
If you are a "PC hero" then stand back and let us work.
THE TPU IS REAL!!!!!
Otto
HopeForHumanity
I notice these people every where on the internet. They trust anything negative they read, and automaticaly think there a know it all. Standard ignorant skeptic....
Time TPU was made and size of generator = no batteries to create output...
Works outside = no hidden indoor power source...
Amount of current = impossible power amount being transmitted...
Doesn't work upside down = pointless to fake such difficult task...
Judging by evidence, I would say the amount of money it would take to fake something of this would be more than the amount of money earned from investors...
Thats just MO... ;)
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
