Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
otto
Hello all,
what to say??
In short:
I made a magnetic amplifier, pulsed it and now again, I have nothing anymore. Everything burned. A lot of smoke and power supply and oscillators are damaged. Totally. Scope, OK, because it was NOT connected.
As Im on vacation from next Monday so please, dont sent me PMs and mails because I cant answer.
For at least I month Im out of "Game".
I wish and I KNOW that the people here can built a good TPU in this month.
Good luck to you all, be very carefull.
Otto
Bruce_TPU
Hello Otto,
I am very sorry to hear about your loss of your oscillators, controller and power supply.  I can imagine how frustrating that can be.  Hang in there!  :(
Warm regards and peace,
Bruce
Earl
Otto,
so sorry to hear this.
May I suggest to all experimenters to only use batteries for testing and NEVER use
regulated power supplies.
Earl
Quote from: otto on July 18, 2007, 01:49:36 AM
Hello all,
what to say??
In short:
Otto
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
ronotte
Hello Otto,
what happened exactly? We all are anxious to help you if possible!!
P.S. and oscillators are not a big problem.
Roberto
otto
Hello all,
yesterday I tried to make a magnetic amplifier like in the picture showed yesterday. A little bias voltage.....2 contra connected coils like in the picture.....and thats it. In 1 moment rised the amperage from the power supply to an value that I even cant imagine.
Now you will say a short. Yes, but this is impossible. ALL my wires are very good isolated....
I really dont know what happened. I only pulsed the coils, changed the frequencies...
OK. Now I finally have the chance to build good oscillators.
@Roberto,
are your oscillators OK??
I have the 4427 ICs, not using them....I think I will build my oscillators like you have done it.
Otto
