Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Gustav22
Hi Roberto,
Quote from: ronotte on July 19, 2007, 05:45:38 AM
I don't understand the reason for the small toroid on the center that you mentioned. May you be clearer?
...while the Bias is correctly applyied the ECD tunig appear to be much sharper and output power increased! Do you have an explanation?
I have noted your 2 questions, but at the moment am not capable of providing a clear explanation.
But please let me again emphasize the importance of the 44 mm (1.75") vertical distance between the two rings which Otto discovered in his experiments.
Let me offer an explanation for the 44 mm (1.75"):
The ratio of the diameter of the big ECD-collector-circle to the small circle is 3:2
Now please see my illustration of a cross-section of the ECD in green colour here:
Please read 2 inches for each symbol 1 in the illustration.
Then you have an exact cross-section of the 6"-ECD
http://www.overunity.com/index.php/topic,1848.msg31317.html#msg31317
The distance between the two rings in the ECD is equal to the height of any one of the small equilateral triangles (black).
Using the formula of Pythagoras the height can be calculated.
It is 1.75" (44 mm).
See also the drawing here:
http://www.overunity.com/index.php/topic,1848.msg31143.html#msg31143
You have a very high factor of power conversion already.
I think that additional EM-coupling between the two circles will occur at the right distance.
This distance is 44 mm (1.75")
money for rope
wattsup
@Gustav22
Good logic on the rings.
@otto
I have a question:
Is there any way to make a tigers' trap to catch the beast and hold it. You can call it going on Ottos' ECD Safari. If using some high value caps in parrallel with a way of cutting the cap when filled, this could give you a good idea on the real voltage / current produced. Maybe you have to catch the beast first before you can tame it.
ronotte
Hello Gusta22,
Thank very much for your calculus. I do agree 100%, I wonder what could happen in the case of multiple rings....I mean if that geometric construction could be still valid!.
Roberto
tim_crouse
Is or has anyone release any drawings of the successful prototype?
I have access to a lab full of equipment, a machine shop, and Labview
If I could assist you folks to get some things some things verified let me know.
Best Regards
Tim C.
bowser03
http://www.rexresearch.com/feg/britten.htm go see the schematic of Chancey Britten's electrical power generator apparatus and notice that he is drawing power from the secondary which is a single wire.  This TPU was already done by him.  He is using one single control coil as primary and attaching it to an antenna to get a pulsed input from the ambient environment.
