Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
13thHouR
Nature normally has ways of doing things much better, the double helix is the most efficient energy transfer/absorption structure for strands.
Those of you familier with WI-FI sniffing will already be aware of how efficient this structure is as a emitter/receiver. You need to get little bit more away from electro magnetics and into the range of radio transmissions to fully understand these TPU's
Some more other tips: As mentioned here previously, isolated PSU such as a battery is more desirable than a regulated PSU.
Even with the best electronics, spike recovery times and feed back will be an issue with mains based PSU's, also DC is not true DC from them. Its a simulation of DC. which will affect the efficiency of the test device as it will create other carrier frequencies.
Do not and I mean DO NOT!!! suddenly ramp through the frequency the spectrum, as the EMP is highly saturated pulse and can land you flat on your ass on the other side of the room. As one individual here nearly found out.
Great for parties, but really trashes your electronic hardware. Plus the neighbours get a bit spooked when objects suddenly fly across their rooms for no apparent reason. ;D ;D ;D
Some examples of the levels of saturation you are creating (In localised terms) in these experiments.
http://www.hfml.ru.nl/levitation-movies.html
I can still hear the Rutherford Appleton Labs in Oxfordshire tell me that was impossible back in 1989.
"They said ion saturation would occur long before levitation".
I replied "That is the whole point of it" and terminated the call.  ;D
Without saturation you can't have compression.
Bruce_TPU
Hello 13th hour,
Welcome to the forum.  I enjoyed your take on SR in the other thread.  But a few quick questions.
Your last two posts on this thread make it sound as if you have a working device, or have experimented along the lines that you mentioned.  In particular the 1x 2x and 3x frequencies that you mentioned.  Can you tell us more of those experiments that led you to the 7, 14, and 21 KHz?  Many of us love theory, but are kind of "jaded" by all of it and are building and experimenting.
Time for some pork on those chops, so to say!  ;)
Cheers,
Bruce
13thHouR
I am isolating those frequencies from a specific document obtain from NT before he died. The rest where lost when his labs where raided after he passed away. Now held by the United States Government.
They are the frequencies used in the genuine PE involving a naval frigate. For the record it had nothing to do with Anti Radar.
The difference on the PE was that on the larger scale they where working in the Hertz rather than Kilohertz band that these smaller TPU's are.
but that is all too cloak and dagger for around here, I prefer to stick to things I can openly talk about without causing trouble for this site.
I have observed specific gravitational effects in other experiments  on the CNFT (cold nuclear fusion tower) when using those listed frequencies. So this is part I can talk with confidence about.
btw the side stepping of your question is not an intentional thing about misleading you. I learned many years ago that dropping all of TDM in somebodies lap has similar effect to handing a caveman a gun. Not that I am saying anybody is a caveman, its just an analogy of the learning curve. Plus I genuinely don't want to get into the whole I can't tell you scenario as this is definitely not the place for such response. So I gave you little of it (just enough to know it is genuine). I did not have an alternative but to use that. I just knew somebody would ask its origin, and I am too honest to lie about it. Lies only get found out and serve to discredit whatever the person may have genuinely said.
ronotte
@13thHour,
wellcome in this thread!
I wonder if that means that we must include Caduceus coil into our work schedule ... Reading intra your lines I'm propense to think that you did already had some real experience as per your warning .... this theme as for the ECD-Mobius IS DANGEROUS indeed.  Please have a look to my next reply to Gustav22 and feel free to explicit your thinking.
@Gustav22,
I do agree with your assesment of present ECD developing situation. It is clear that the conditions that lead to ECD run-away condition are not stable/reproductable.
I did many tests in order to find a more stable design but for the moment I did not succeed. Anyway some new points have been reached: the multiple Seeds appearing and the associated automatic RE peaks converting into justapposing sine pieces is to be considered EXTRAORDINARY. No way for me to explain it! I hope that both Jason, GK and several other will soon be able to experiment on this ground.
It is clear that at least the actual CC design is not correct, it needs to be reconsidered, I will join Otto on 20 of August just to plan a strategy to follow for next September. I do also urge all to use synched frequencies using one of the many circuits posted.
Some practical hints:
I do confirm that for the 6" ECD the first correct freq is in the range 25 - 30 KHz, the second is also fixed as it is the second harmonic: in this case may range from 50 to 60 KHz, the third frequency may be the third harmonic but...in many cases I've had good results with 5th or even the 9th harmonic.
Best luck to all
Roberto
BEP
A friendly note on EMP generation - use it or blow it off - your choice.
Forget shielding. Don't waste your time. Grounding is useless, as well. I don't care what you think you know about Faraday cages.
They will not stop the pulse unless they are 'active' cages. By that I mean generating their own equal intensity field of the same polarity and type. Good luck building one unless you have experience in EW, ECM and ECCM.
Of course, none of us have done this before so the above is just hot air   :)
