Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 31 Guests are viewing this topic.
wings
ECD-Mobius IS DANGEROUS ?..
Assuming that the Mobious coil is a scalar wave antenna :
http://www.mathematik.tu-darmstadt.de/~bruhn/Commentary-Oschman.htm
This document ?Capt. Robert M. Collins (TQTR), "Soviet Research On The A-Vector Potential and Scalar Waves (U)," Unknown? from: http://www.unusualresearch.com/scalarbib/scalarbib.htm
give possible conseguence of the use of dual mobious coil, see the page 5  para ?Ad hoc Theories on Scalar Waves?  Summing two scalar waves??.the ultimate ecological catastophe?
Ciao Marzio
Motorcoach1
 now thatsÃ,  funny-- I just posted a photo of my semi Ottos mobius coil set up on Maniux thread , take a look mabey I should reconcider this set up , mmmmÃ,  2 rings aluminum and braded coax fed throught the pipe,Ã,  tight fit . getting ready to wind the aluminum and the bias windings .Ã,  stop or go ahead? I'm testing on a concrete room very small and all test equipement is 30 feet away with cameras set up, when i did a test on another coil my camers started to get blurry but kept working , strange effects before to lighting hit.Ã,  >:(
13thHouR
Quote from: wings on July 23, 2007, 12:35:33 PM
Ciao Marzio
You are correct in one sense about the dangers, at the moment on this small scale most people are only experiencing rather odd self resonation, the Hutchison effect if you prefer. I was just warning people to be very careful of the energy saturation density. As they are already observing the gyroscopic effect.
You can accidentally create a short burst EMP (I use EMP for want of better word, as there is currently no wording to describe this phenomenon without delving into deep explanation of TDM and Hawking's Arrow, I am reluctant to add yet another word to the several I have already had to create)
However I need to bite the bullet and give this a name. The nearest description would be a Gravitational Electromagnetic Pulse (GEMP), which is combination of gravitational shift and electromagnetic disturbance locality of the experiment.
It's basically an intensely saturated  magnetic pulse that to non magnetic objects it becomes Kinetic instead of electromagnetic energy.
This is an example of a sustained GEMP in which a organic object (around 2 gauss) is levitated
The frog freely floats in the over saturated magnetic field. In that experiment the magnetic field is over 1000* more dense than a normal permanent magnet.
innovation_station
i have a question
   why does steven use a permanant magnet when he first starts the coil up? or placed in the ring or on it ?
might this be part of the reason why if we have a spinning magnetic tornato in side of the ring could it be used for driiection of spinn of the tornato and used to make electrons flow in the collector wire because he removes the magnets on some tpus and not others i think the magnet helps to hold the electrons in side the ring  or if in attraction maybe  it sucks the electrons in to the wire
is
Dingus Mungus
Make a solenoid coil and pass a manget over it or on to it while measuring the resistance. You'll notice the tiny fluctuations in voltage equate to great changes in resistance. The harmonic effects being discussed have to do with resonance which is dirrectly correlated to coil resistance and perhaps presence of B field to alter resonance on one of the coils. Like a key to start the ripples. BUT there were models shown with switches and the like. Unless he had them going SS, and the switch opened the output only.
All just theory though,
~Dingus Mungus
