Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
mrd10
Hi Otto,
That is true, there is alot I read, and I read and re read from Lindsay and Steven, and things are still stuck in my head. I'm glad that you have continued with the work, and have no way given up. I solute you.
I have gone a different path, with John bedini's work, I still have an energizer to finish, But i'm glad you have continued on.
I spoke to Roberto the other night and he speaks very highly of you, I actually thought Wow because your from Crotia, where another famous person by the name of Nikola Tesla came from, your country men, hehehee you must have an edge on all of us because of that fact......
Again, to All who have kept going, Thank you
Dominic
hartiberlin
Quote from: bob.rennips on June 12, 2007, 09:54:15 PM
Whilst waiting on the exact driver as used by Jason I thought I'd do a couple of tests.
I wanted to see if I could capture what was happening, signal wise, when say a 90khz and 180khz was 'mixed' in a coil.
To do this I wrapped a standard solenoid coil. This is the mixed signal coil. On top of this two parallel wires wrapped together to produce another two coils. i.e. As if wrapping a bifilar coil.
Into the two parallel wrapped coils I fed 90hz into one and 180hz into the other. The attached image shows the 180hz on the top trace, the 90hz I've drawn in in red, the bottom trace is the resultant output. The drawn in red line on the lower trace is the 0V level.
The staircase on the output goes down because the input signal are synchronised on a rising edge. I'll try moving the input signal to synchronise on the trailing edge so that the staircase goes up.
If this output were DC shifted up say 100V, you would have a situation where, in the case of a rising staircase, you would have progressive dc pulses WITHOUT A CURRENT REVERSAL. We know from Tesla that Radiant Energy occurs when pulses are applied in such a way that their is no current reversal... Further more, if this staircase effect was to occur on a high voltage spike, due to further mixing with other coils and you have the situation where you are generating high voltage DC, non reversing pulses.
I think part of the puzzle is to get this staircase effect happening on the leading edge of very high voltage BEMF pulses.
EDIT: I had the AC button pressed on my scope instead of the DC. I've therefore redrawn the 0V level on the attached image. The 0V level is at the bottom of the lower trace NOT centered on the lower trace.
Okay, but then your red lower frequency must have double the amplitude of your green square wave,otherwise you will
not get this staircase wave just by adding them up...
shuzammy
Quote from: otto on June 13, 2007, 05:40:50 AMSM told us that there are a lot of ways to built a good TPU. So, in a very short time, I suppose, there will be TPUs like the open one with the controlls wound all over the collector and a few other types.  I only wanted to give the basic setup that I have. Its on you to find other possibilities to built a good TPU. Otto
With that in mind I wonder if there would be any merit in considering how a TPU may be wound in a Tensor or Caduceus Coil manner.
"This coil has repeatedly been found to violate established laws of electrodynamics and hertzian wave theory when high frequency is injected into it."
"This apparatus has zero impedance - unlike an ordinary coil."
"It has infinite resonance - unlike an ordinary coil which will resonate chiefly at its natural fundamental frequency and weakly on the 2nd or 3rd harmonic, the Tensor coil is capable of resonating strongly on any number of frequencies randomly spaced in the spectrum."
"A few investigators have also reported unexpected bizarre inertial effects (READ: "gyroscopic effects"?) in conjunction with these coils."
Perhaps if one modeled a TPU after the omni-resonant antenna-like features of human DNA (caduceus style), one "may" inherently solve the problem of TPU super nova ("spontanious combustion")... ?
- http://uncletaz.com/library/scimath/cadcoil.html
- http://www.keelynet.com/time/cadsmith.htm
- http://jlnlabs.imars.com/spgen/
otto
Hello all,
@shuzammi
I tried the canduceus way of winding my control coil but I had no success. Maybe I did something wrong but I would prefer, for now, to use just "normal" coil windings methods.
Otto
hartiberlin
Hi Otto,
is really this moebius coil form needed or can one also be used
just a normal standard coil as the collector coil ?
