Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Mannix
Any thing I do is about making this technology available..
The best way that I can .As I learn more, the methods will change...everybody do the same.. and we will have it.
A question that was put to me was . How long will it take for replicating people to be able to perfect the generator to the stage that Steven has?
I did not know the answer but i liked the challenge in the question..
Perhaps validation will work in their favor.
Im not answering about patents and people who want to copy....Its been covered many times..
Lindsasy
Earl
Hi Bruce, hi All,
Bruce posted >>
SM suggested in his posts, to build a "mini tube amp" using Mosfets, to power the TPU, to start with.  He said it would be faster all around, to see something happen.  Can you explain as an electronic guy, how close to what is being done, is to a mini tube amp?  Is there any similarites?  What would the difference be?
I think this is an important post of SM's.
I don't know exactly what a "minitube" is, but it could refer to a RCA tube from the 60's.
The nuvistor was developed by RCA and it was first introduced in 1959. Nuvistors were the latest tube development at just about the same time as the introduction of the first integrated semiconductor circuits. A nuvistor is a miniature vacuum tube in a thimble sized metal case.
Nuvistors were also produced in Europe (by Philips/Mullard, Siemens and Lorenz) and in Russia.
Tektronix used nuvistors in the front-end of their oscilloscopes in the 1960's.
Neumann used the 13CW4 triode nuvistor in the famous U47 and U48 mics for a while when the Telefunken VF14 pentode wasn't available anymore. AKG used a nuvistor in the C12A mics and a RCA 7586 nuvistor in the C61 mics.
The first nuvistor to be produced by RCA was the 7586.
Musical Fidelity used nuvistors in their Nu-Vista 300 amplifiers and their Nu-Vista 3D CD players. Only 500 pieces of each were built.
Conrad Johnson used two 6CW4 nuvistors in their HV-1 and HV-2 Phono pre amps in the 1980's.
Nuvistors are mostly trodes, but one tetrode was also produced.
I am unable to dechipher what SM said in order to determine whether the exitation coils should receive sine or square/pulse waves.  Nor what is meant by "pure frequency"?  It is good that there are enough researchers here that some will try using pure sine waves, while others will try pulses.
Most high-quality audio oscillators have amplitude regulation which prohibits a fast change of frequency.  Sweeping frequencies is not so easy.  The only way I see arround this is to mix an HF variable frequency oscillator with a stable, fixed frequency and then use a good low-pass filter on the mixer output.  Or use a professional synthesizer.
It can not be excluded that there are more than one type of "TPU".  Photons at light frequencies were first produced by fire.  Nature used arc discharges.  Then incandescent lighting was invented, followed by LEDs, then laser diodes.  UFOs contactees routinely comment on lighting in the ships that appears to come from everywhere and nowhere:  it's just there - with no apparent source nor shadow.
It is possible that someone following SM's route will stumble onto another successful road, a "mutant hybrid clone" so to say.
Many will stumble over rocks, no matter which road is followed.  The important thing is not to give up.  Get up again, dust off, stand tall, and continue.  Failures do not exist unless you keep them to yourself; if you share them team knowledge is increased.
It should be clear that a lot of "brain busting" lies ahead of us.  For example in order to create a rotating magnetic field, four coils equispaced need phase offsets of 90 degrees, while 3 equispaced coils need electrical phase shifts of 120 degrees.  just dumping random frequencies and/or random phases into coils will not create a rotating magnetic field.
A major question is:  does the TPU need a rotating magnetic field?  If yes, then in my opinion, no one is doing it.
I have released one idea, along with concrete schematics, and will shortly be releasing other schematics.
If a rotating magnetic field is not necessary to operation, then random pulses are OK.  I will also be releasing concrete examples and schematics for random pulse generation.
It is a pleasure to see so many people cooperating in a dedicated manner to achieve a common goal, a goal that is getting more urgent every day.
Regards, Earl
steve_whiss
Hokay,
Back in the world. This re the Steve Mark device patent and that patent number I quoted.
My interest in SM's work starts when I saw it here back around April 2006, and during that time found links appropriate. Don't ask me the details though, over a year ago - this is just what I came up with at the time.
http://appft1.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PG01&p=1&u=/netahtml/PTO/srchnum.html&r=1&f=G&l=50&s1='20020125774'.PGNR.&OS=DN/20020125774&RS=DN/20020125774
The Continuous Electrical Generator. Now this could be a different thing and someone elses work, but it looks and is described the same. I expect I found a link here and just went all over the web like a mad snail. Where I heard of it first <checks>
Um, try this one:
http://www.zpenergy.com/modules.php?name=News&file=article&sid=149
that's in my Steve Mark notes too. Has the link to the same patent.
Got a pretty big pic of the front page - trying to attach.
Steve
steve_whiss
..after reading Earl's post:
Note that the device above is all about rotating fields. With this unit and 6 poles, a well-shaped field with a smooth AC profile (no spikes) can be formed and rolled about the core.
Suspect the replication has found a new method - rocking not rolling a magnetic field.
If that be the case the replication may work with a magnet replacing the 12v coil.
Steve
TheOne
From a noob point of view (me), someone thinked about using magnetite/blacksand for the core of the tube/ring?
Maybe they are something missing, blacksand are highly reactive to magnetic field
