Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
gn0stik
Ok, AS I SAID, I did not intend to make everyone give up! We haven't even completed replicating yet. To my knowlege nobody since Ronotte has gotten to the third frequency yet, and tuned according to the document. So, What I would like to see, is people perhaps getting to that point, tuning exactly to the document, performing all suggested tests, and doing this experiment again.
It could be that catalyst happens in this setup when the third frequency is added. Three is important and all that jazz. All we have proven thus far is that without the three frequencies it behave according to the tesla transformations as seen in the tesla coil.
I sincerely hope that this platform is not abandoned by the experimenters. Perhaps my timing is not that great.
I want to make someting clear. I am still going to build this as I feel it would be patently unscientific to just walk away without seeing ALL the effects mentioned in the doc. We know that they were telling the truth. But we have yet to bring a device up to full operation.
So, there you have it.
Also, it may be that, as I said, the device has "modes" of overunity. It will power a standard load with normal input if the normal input can handle it, but give the energy source a reason to flow, and it will. Know what I mean?
Anyway, more testing is needed still.
Thanks for the advice Mannix. Of course with no collectors in the device we were not spacing the collectors. We had removed it alltogether to test Darren's hypothesis.
Oh, and someone said it was my test. I can't take any credit as it was cam's hands doing all the work, and I was actually a late comer. Didn't mean to take any undue credit. I was on my way out the door, at the time I posted.
Regards all,
Rich
wattsup
@ Any answers for the Q&A needed
I'm not asking onyone to test this. I'm just asking too see if I should wind mine like this?
1) Could the frequency be sent to the primary void instead of the primary negative. By just putting a center tap on the primary when winding the bifilar CC. Is it electronically permissible?
2) Would doing number 1 permit you to remove the ground off the IRF840, or,
3) If the IRF840 needs this ground to function, would doing number 1 reduce the load comming back to ground on the IRF840? An educated guess.
I feel these are three very very important questions as this could give a whole new domension of being able to test parallel and series  CCs, while trying various ring point connections.
gn0stik
Quote from: wattsup on June 16, 2007, 01:22:06 AM
Hmm, that's a very good idea wattsup. I think it would allow for some decent flexibility for sure.
How far along are you in your build? Please post pics when you get to this point.
Regards.
Rich
Hoppy
Dom has clearly demonstrated the transformers working without the need for the Mobius coil. I presume his supply voltage was around 12V which would have given 36W consumption by the setup Assuming 50% transfer efficiency this would give around 18W consumption by the bulb which looks about right from the illumination.
Using thicker wire on the secondary, say the same as the primary at 0.5 should improve the transfer with a 1:1 turns ratio. It's well worth experimenting with the amount of ampere turns and graphing the drive current in relation to frequency to get a better understanding.
There are some very interesting solid state Bedini variant designs around utilising the principle shown in Dom's video. I have built some very effective battery chargers using HV radiant energy at audio frequencies using air iron and air cored inductors. The secret is getting the pulse rise time as fast as possible and as we know Mosfets are fine so long as they are driven properly. I suggest the use of high voltage, high power TVS diodes across Drain / Source to supplement the 'slow' protection freewheel diodes integrated in the Mosfet package.
This is an interesting and absorbing area for experimentation where much can be learnt - have fun!
mrd10
Hi Hoppy,
Cam was the one that was in the lab, i was just his assistant, and jotted things down as we went along. In video were using 12volts (battery), note also video was done after we did alot of testing. Do not stop testing your setups, add the 3rd freq and do more tests.
We just did this because this is the time we had and we did it.
Also this is a reference point for other builders that can verify what we did.
Sincerely,
Dom
