Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
gn0stik
it definitely has a tendency to be effected by magnetic fields. even low intensity ones.
You can change the frequency when it's hooked up to a tpu style winding simply by waving your hand over it.
Pretty interesting they are, but ultimately not OU.
In one of our hive mind sessions we had a similar moment of amazement. Ultimately it turned out that the power was coming from supply however.
This was with ottos 50 turns setup. After that ended up not working, we started playing around a bit and stumbled across the blocking oscillator cct. Kinda freaked us out that it just rung by itself.
still very cool.
eldarion
Could someone please make the high-resolution videos available somewhere for me?  I have some video processing software that might be able to enhance them even further.  I am especially interested in the original 25W TPU video.
I would be happy to mirror them, original and enhanced, on my website.
Thanks!
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
hartiberlin
Hi EM,
thanks for coming clean and seeing your faulty digital meter.
As I always say to people in overunity research:
Just only use analog meters.
You can much better see all the effects and pulses would not confuse
these meters so extremely...
So EM,please go on.
Maybe you will find some other interesting effects with your blocking oscillator.
Regards,Stefan.
EMdevices
Thanks for the encouragement, Lindsay and Stefan
I'll continue to play with the BlockingOscillators, they are quite interesting.
EM
Thaelin
@ Stephan:
   That really depends too on what kind of signal you are trying to measure. I was expecting ac and actually was seeing an RF. Made my analog meter do all kinds of stupid things. Same reading on 3,15, and 60v scales. Each will have drawbacks. That is when the scope will prove invaluable as it sees the pulse durations as well as the peak.
sugra
