Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
Thedane
Quote from: EMdevices on June 25, 2007, 09:07:48 AM
I'll continue to play with the BlockingOscillators, they are quite interesting.
EM
You might want to place a series voltage regulator on the blocking oscillator supply.
This ensures that replication is a little easier because you're not dependent on the exact supply source and its variations.
A simple 7805, LM317 or similar is perfect. Don't forget to add a few 100nF capacitors on the input/output to decouple noise.
eldarion
Well, I thought I would post this here since at the beginning of this thread there was an attempt made to identify various components of the TPU.
There is a device that looks suspiciously like a flouresecent tube starter on that TPU, and while I was researching the operation of such a device, I came across this at http://www.eio.com/repairfaq/REPAIR/F_flamp.html#ba:
Quote from: Floursecent Repair Guide
A ballast serves two functions:
1. Provide the starting kick.
This would seem to confirm which type of kick SM is talking about if that really is a flourescent tube starter on his TPU.
Just a thought.
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Hi Elderion,
I agree and mentioned that also, from a similar perspective here, 4th paragraph, second line:  In reference to SM's bias linked capacitively to his primaries.  In the open tpu any way.
http://www.overunity.com/index.php/topic,2300.msg40581.html#msg40581
Cheers,
Bruce
eldarion
Quote from: btentzer on July 20, 2007, 11:26:33 PM
Hi Elderion,
Cheers,
Bruce
Bruce,
Thanks for letting me know of that post!  Lots of interesting information there. :)   I didn't think I was the first to notice it, but I just wanted to throw it out in case no one had posted it.
Eldarion
-- Thomas Paine
