Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
EMdevices
Let's talk about plate TPU2_1AÃ,  and TPU2_1B
The interesting pattern with the 4 knobs and the holes makes me think,Ã,  THEY WERE NOT CUT FOR THE FUNCTION BUT CAME FROM SOMEWHERE ELSE.
1)Ã,  Through one of the holes we see the gray box TPU2_4A, doesn't serve a purpose.
2)Ã,  The top plate has no coils, so it could be for support purposes
3)Ã,  The top plate could conduct flux if its magnetic, is it?
If we can identify an object from which these forms came, we might know the composition.Ã,  Keep your eyes open.Ã,   A spool of sorts?Ã,  Speaker cover support frame?
So far we have:
1)Ã,  Plastic
2)Ã,  Copper
3)Ã,  Iron laminations
I'm more interested in if its magnetic or not.
EM
BEP
EMDevices,
On your 'copious free time' you may wish to consider some light reading on Fractal loop theory - especially folded and twisted loops. Not usable at this stage but....
As far as the two rings.. My theory:
Both Fe shaping the fields of the PMs.
Both being separate parts of a different style of primary.
You place a coil wrapping between the middle of a core to the outside - would that then 'twist' the field of the PMs? I don't know but I will find out this weekend.
Would this then be a form of waveguide between the plates?
<wavewatcher account no longer functions - I will continue anyway>
EMdevices
Welcome BEP,
Ok, so we now mention a waveguide.  I'm with you.  If they are metalic (but not necessarily feromagnetic)  we do have a circular wave guide.
So we jam more and more power into the ring untill the fields build up to high levels.
I'm an open minded guy :)
EM
P.S. Here's another photo I processed.
hartiberlin
Hi EM,
nice image processing !
I had seen somewhere also some pictures of this video in
interlace full 720x576 format,I guess it was on the gn0sis.com
ftp site, so I hope you used these to make them clearer
as they were more high res as the video only had 320x240 size.
Now what about the white coating on the outer surface of
TPU2-3A ?
Is this the white cable from the output going there around the magnet ?
So is there this white wire taped around the outer surfaceof this black shell ?
Maybe with black tape, so you can?t see the white cable anymore ?
Regards, Stefan.
P.S: Here is the link to EMdevices pictures:
http://www.overunity.com/index.php/topic,2579.msg36395.html#msg36395
EMdevices
Stefan, Very good question.
I think the white might be the color of the TPU2_6A  (the leg)    But it could very well be GLARE, or wires and black tape covering the center.
We'll get to the wires eventualy.  We can do alot with the images.  (I processed the high quality images)
EM
P.S.  Take a look at the image, lots of interesting info.
