Solid state Bedini charger from John Peters
Started by hartiberlin, June 22, 2007, 06:23:58 PM
niofox
Quote from: mscoffman on May 07, 2010, 02:57:40 PM
Unless the battery has been abused somehow, emptying the cells
contents make no sense. The sulfur comes out of solution in the
battery during discharge so you really should try to allign the ratio of
electrolyte to water concentration with the level of charge the battery
was at, at the time you emptied the contents.  of conservation
of matter says you would only ever need to replace water which
evaporates or gets electrolysed out of the cells. Adding commericial
battery additives is the exception. I've heard of  the battery,
off with, but not putting  into a a/l battery.
:S:MarkSCoffman
Apologies for the mis-communication.  I didn't mean adding baking soda to the battery, it was for neutrilizing the solution that was poured out so that when you throw it away it doesn't harm the surrounding environment.  Also, for safety reasons.  If you got some strong acid on yourself I was told that throwing on the baking soda and washing would be helpful
SkyWatcher123
Hi niofox, thanks for the reply. I did try the circuit you posted and could not get it to oscillate, are you briefly connecting from collector to base to get it started or something similar, because i dont see what is biasing the transistor on. If you flip the switch as shown no current will flow through the primary because no base current is flowing. Would sure like to know how your getting it to oscillate, thanks.
peace love light
Tyson
guruji
Hi Niofox yes about that schematic I had printed it in the past from someone else. Does that mean that one has to put all coils on to one?. Or one bifilar and the secondaries as single coils?
Today I tried a bigger awg coil but could not oscillate with my setup  :-\
Ok thanks anyway.
niofox
Hmmm, it may be possible that my project board has something shorted that is making it work.  After I get done moving this weekend I will try to construct it without the project board to see if it works.
The coil I am using is a bifilar #23 + #26, 1/2lb total weight, 12"x6" oval (no spool).  Not sure about length or # of turns.  I put some tape on to keep it tightly together
I am using a switchable adapter as my input.  Its set at 15v but outputs 19v under load.  Rated at 2amps max
I have not tried using 2 batteries in series yet, but I don't think it would oscillate at 12v.  It seems like the initial switch on kicks it into oscillation
I am sorry I cannot test things now.  By Monday or so I should be settled in at my new place and will start on this then
guruji
That circuit is good for a certain lenght of coil I think. This new coil that I did was not oscillating but when I shortened it a little there's a hissing sound. So now I would do a lesser resistor than 10k and I think it would oscillate. Cross fingers.
