Scope shots of clean kicks
Started by bob.rennips, June 26, 2007, 11:07:47 AM
starcruiser
@Earl,
I was gonna suggest an R/C network to allow phase shifting as well.
Regards,
Carl
Grumpy
shift register = ring counter
Have M74HC164B1R (SIPO) and M74HC4017B1R counter.
        -Frank Edwards
eldarion
Well, I'm in on this attempt! :)  It looks to be very promising.
I've wound the coils (minus the outer pickup coil wrapped around all three--picture is attached.)
I'll use my FPGA to generate the exact timing required here; just waiting on MOSFET drivers (again!).
Results will be posted on my website and here.
Good luck to all!
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
chrisC
Hi Eldarion
It would be really good if after you get Earl's synchronous dividers to work and then integrate them into a FPGA. Then with a few external pot & discreet RC the pulses can be generated with minimum parts? Keep us posted. Thanks.
chrisC
eldarion
Quote from: chrisC on June 27, 2007, 07:21:41 PM
Hi Eldarion
chrisC
Chris,
I was using an FPGA so that if I ever did get something working, the control algorithms could be implemented on the same piece of hardware with minimal effort.  Also, I can generate extremely accurate frequencies with the FPGA, something I am not sure an RC oscillator can do.
Just my $0.02 :)
EDIT: Looking at the coils above, I noticed a sort of spiralling rotation, as each control coil is higher than the previous one, then it resets at the first coil.  I wonder if that would pump "something" through the coil?
-- Thomas Paine
