HHO Implosion Engine Study
Started by IronHead, June 27, 2007, 10:07:12 PM
IronHead
Nice,  More input. Everyone I want to hear some ideas on this stuff  this is great stuff right here!
s_c_engineering
i went and got some food and thought about this.   1860 times the size.  so in a cylindinder. no valves, basically taking the head off of an engine and putting a injector in the middle of the cylinder.  well not really a injector... for example with stans injector he had about .010 gap between teh center electrode and the outer.  so you have what maybe a 1/4ml of water in there prob less.  so anyways you use 1.4 v and whatever amp you need to get rid of that water. turn it into hho.  then you use a heating element in this "ceramic insulated" injector that then expands the gas further giving you optimum conditions for implosion.  at this point the expanding gasses have allowed the piston to go back down to the bottom.  (keep in mind this whole reaction is in a vacumn it just is going to expand as far back as it will let the piston go)
then you release your spark which is according to the browns gas 9kv so im sure that a spark plug spark would do just fine.  this hv "lightning" causes the implosion reaction sucking the piston back up.  whats left.....
the water you just disassociated... its back in the injector because the "solid plate head" has a gap of .01 between it and the piston.
low drag plastics?  ptfe...   EDIT Delrin.      what type of engine... i dont know has someone tried it on a car engine, i seriously doubt it, and if they did you would have to replace some things,you couldnt have any oil in there to lubricate.  id like to see it in a radax style engine.......
ive also been contacted by a member here last week whos interested in posting up an engine design.  words have been thrown out such as 1 cycle... along with some other parameters... anyways hopefully he will post it up he said he working out some details cause he wants to split it up...
PEOPLE POST YOUR IDEAS ON HERE... or put links to other threads that have your ideas proposed for harnessing this energy.   Im really sick of hearing about supression cases on the internet.  this is free source.  thought of right here.   but... if your going to throw out an engine design include a theory on how to harness this power.. dont just say "this engine"  thats what we should use.. ya know
if you read into browns gas you cannot boil water with hho.
s_c_engineering
on a side note... these hho torches will weld metal to bricks.  melt metal, take ceramic to the heat of the sun (blows a hole right thru ceramic tiles)..     hho reacts with what its burning from what ive read and takes on the properties of what it burned as posted above....
IronHead
It is about heat propagation  not heat produced . There is little propagation in an HHO explosion or implosion   but the plasma thing that is a different thing all together.
I think a good candidate for such and engine to start out  as for piston type might be an oil less air compressor motor. If you did a car engine or 2 stroke or 4 stroke  made for fuel you will need to not only replace the rings but also the bearing to run in a no oil situation. So  sealing up a 2 stroker might be a way to go and for big stuff the Detroit Diesel 2 stroker
s_c_engineering
ok  nother thought.  can you turn water into hho with low voltage at high frequency at a fast enough rate to diassociate the water... or would you need something similar to stan meyers hv diassociation to be able to make hho fast enough.  this needs testing also  im pretty sure its gonna need to be hv low amp
nother thought.  stan meyers used "stainless steel wire"  right....   what if he used nichrome wire inside of this ceramic in his injector to act as a resistor and to heat the injector to expand the hho gases as they disassociated.  we can have steam and hho in the same space right.    and vacum allows water to boil at lower temperature.
just ideas...
