HHO Implosion Engine Study
Started by IronHead, June 27, 2007, 10:07:12 PM
keithturtle
I read thru the entire document; it seems as though the hi temps would give the input pipe fits... there ain't much air moving in thar.
In fact, the only input is HHO, with a vent in the top.
Materials integrity is fundamental to Kim's design, but I see no reason why it cain't be replicated- it's so dang simple it's scary
Turtle
BTW robb077; do let old age put off yer building- we old folk know a whole lot about what don't work in the first place...
"learn from the the mistakes of others- you'll never live long enough to make 'em all yerself"
Soli Deo Gloria
Robb077
Keith:
Maybe just use a sandblaster ceramic tip for the input into the vessel. Yeah, it is simple and no parts to wear out. Could use to heat or steam water for many uses.
The thing is just made from firebrick and ceramic so not so much to worry about integrity...just keep temp below 2000 C with these materials.
Maybe Ironhead can start a new thread for this...HHO Heater or whatever. Probably a good idea to have another thread to work on this.
keithturtle
I like the sandblast tip idea, so I got one with an eighth-inch bore.  The green rod I got is 3/32, so I'll sleeve it with shrinkwrap to reduce stray current.   I got a stainless whisk, and found that the nozzle can be cram-rammed thru the wires, and project the tip in the center of that thar elliptical chamber, although the radius is obscenely great, >1" at center.  Shroud the outer periphery with SS steel wool, and that should work, I thought.   Ain't tried it yet, cuz I came up with sumtin better.
Another trip to Target  (it ain't on their site else I'd post it) yielded another whisk of a spiral-wrapped configuration, 316 SS, that has a progressively reduced radius, and a perfect round opening wherein the tip can be inserted, no "Boar-hogging" necessary (that's an old body shop term for making "Chinese no-fit" fenders go on the car).
Anyhow, I'll assemble this simple arrangement this week and post pics and results in the Cold Fusion thread.  I'll parallel the bridges to keep heat down.   Might even use two separate feeds (same phase), 4 bridges and watch the sparks fly <BIG GRIN>
More at the thread.
Turtle
Soli Deo Gloria
IronHead
HHO heater is best  posted to the Plasma  thread
thanks guys
http://www.overunity.com/index.php/topic,2058.new.html#new
EDIT FOR LINK
keithturtle
Where is that plasma thread?   I don't think I've found it yet, and I must needs be there.
Turtle
Soli Deo Gloria
