Thanks to ALL for your help!!
Energy from Still Air
Started by ltseung888, June 29, 2007, 07:47:22 AM
ltseung888
Air is not a fuel.  But Air is an Energy Carrier.  When we pump Air into a machine, Energy will be carried by Air into the machine.  The formula for the energy is
Energy of Air In = Pressure of Air In x Volume of Air In.
Energy of Air Out = Pressure of Air Out x Volume of Air Out
This difference is Energy of Air that can be used.  This is in addition to the Pump energy used to get the Air into the machine.
Details in the attached article by Forever Yuen.
pese
this is the system , as the air-compressed cars drive.
but this is expensiv to compressing the air.
if you have enought energie lirke from wind -generators , you can
take an compresser , instead electric generator.
mor over this technic you find on leebell homepage
(here as member "freebell"
www.leebell.net
G.Pese
ltseung888
Dear Pese,
I enjoyed your website.  It has a lot of good ideas.  Our actual implementation of Energy From Air is to use the Energy from Electron Motion Pumps as the primary source of Energy.  They are more compact and more efficient than the Energy from Air pumps.
However, Energy from Air can produce Global Cooling.  This can reverse Global Warming.  Thus it has its place in history for this reason alone.
Dingus Mungus
Not to be the nay sayer here, but when the air is compressed its heated, and when its released it cools down... So I imagine it would "ballance out" in the long run.
ltseung888
Dingus Mungus,
Like all the scientists who have been unconciously ruled by the Law of Conservation of Energy, you still have not realized the statement that Air is an Energy Carrier.
We already assume that when you compress the air, that energy is part of the pump energy.  This energy goes into the machine.  There is the additional energy from air which scientists have overlooked for centuries.
Consult your professors at MIT, Harvard, UCLA, Stanford or any of the top Universities if you are in USA.  Many already accepted the theory.
