The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Bruce_TPU
I am being a helping soul.  :)  Besides, one never knows.
Also, not long ago, I heard a story of someone who put long waves into a coil and got a surprise.  I am just helping out.
Brn brades idea is to have several of these coils in a circle in ECD fashion.
Besides Mannix, I am always looking for pieces for they add up to the sum. ;)
Cheers,
Bruce
chrisC
Brnbrade & Bruce:
A couple of weeks ago, you had a set-up with a vertical large magnet positioned over the coils. What is the difference between what you showed to what is here? Can you please draw a simple circuit and some more information about the sound?
It does look a lot simpler than a TPU/ECD, deceptively simple.
Also where/how is the loop closed?
Thanks
chrisC
Bruce_TPU
Quote from: chrisC on July 01, 2007, 02:22:18 AM
Brnbrade & Bruce:
Thanks
chrisC
Hey Chris,
You can see where the magnet is in the pictures.  Right behind the coils.  It is large.  As for the sound waves, what do you want to know?  Stereo, two channels, I believe from his other posts.
He said he was wanting to close the loop in the future, ie switch the battery off, and also put it into a round shape that is more appealing to some here.  LOL
I asked him to get back to us when he takes a picture with a bulb attached, regardless of how bright it is, while he looks to borrow an amp meter.  He is anxious to prove that it is not a transformer, but that the magnet is interacting with the oscillations through vibrations on the coils to produce the additional power.  I think I said that right for him.
Cheers,
Bruce
brnbrade
bob.rennips
Hi Brnbrade,
Thanks for posting. I think you need to provide a detailed drawing of what wires are connected to what. The placement of the magnet. Where the poles are of the magnet are. Where the +ve. and -ve of the battary go. Whether the batteris are in series or parallel etc.
I really don't want to have another guessing game, SM pictures are quite enough!!
But in the last picture showing 250V the magnet does not appear to be part of the circuit ?
This circuit digrammer is quick and easy for drawing components and linking with wires:
http://www.falstad.com/circuit/
Select Menu 'Circuits' - item -'Blank Circuits' to get going.
RIGHT CLICK to access all the components and wires.
Cheer, Bob
