The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Bruce_TPU
Good Morning guys!
@ Earl
Thank you for the circuit.  I put it on post #1, our build page.  Please check it with ALL info on page 1 and check it for accuracy.  Great job!
@Rob
Thank you for the aprox wire sizes!  I put it on page 1
@ EVERYONE
SEE page 1, post 1 to build!!
I have turned it into our build page and we have ALL the information we need to replicate.  Thank you.
Quote from: sugra on July 03, 2007, 06:52:08 AM
Hi All:
   Did a small test tonite of a bifilar wound coil. Reason I feel it belongs here as well is that the internal core is, you guessed it, aluminum solid 1/4". Was mainly seeing what would be the difference with an AL core as opposed to a CU core. Well output around 80v. Signals input from opposite ends.
   Now this is the part that is weird. Rod is 24" long with 4 layers of twin #20 stranded. Scope is on each end of the rod. This AL thing is starting to push my imagination around a bit. Anyhow, Bruce... so here is two ocurances of the opposite signal injection showing great results.
The other coil was the same idea but bifilar wound on a pitsfield coil with a whole lot of turns of wire wound around the center hole at 90 degrees to the bifilar pair.
sugra
Please, everyone pay attention to what Sugra has posted!  It is more confirmation, of another TPU ingrediet and other FE devices!!!  Thank you Sugra.   ;D
Happy, Happy days!!  (P.S.  Many many similarities to the TPU)
Bruce  :)
Earl
Quote from: gn0stik on July 03, 2007, 10:10:36 AM
So now he has it running on caps?
Well, I have my plate in front of me. All of my words are piled on it.
If someone can replicate these results and explain it, I'll eat every last one.
Anxiously waiting.
The "taking a break for two weeks" thing is familiar, though. The diagram, shouldn't be that hard to scribble out in notepad. How frustrating.
Earl, in your diagram, should power be input via the primary and output via the secondary, to the next device's primary? (which may or may not be inverted)
Rich, no power should be input.  It is the Creator's aether which is the input power.  The only thing necessary is to perturb its equilibrium and then it will start oscillating by itself.  This assumes that your losses are not excessive (and that this device works).  I suggest everyone reading Harold Aspen's talk that he gave at the Berlin FE conference.  He refers to the Cook patent and presents his own idea how to build a device using high voltage and cross-linked concentric capacitors.  You could say his idea is the dual of Cook's idea.  Either low voltage with coils or high voltage with concentric capacitors.  He explains his concept of aether.  Highly recommended to read the last part where he talks about Cook as well as his concentric capacitor idea and how he sees aether.
You do not need batteries nor stereo, nor anything.  Just a perturbing impulse to start it going and a permanent load to keep it from stopping.
Bruce, please add the PDF from Harold ASPEN to your post #1 on Page 1.
Regards, Earl
Basically what you have done is a couple conductors with chokes in them..
brnbrade, please post a cct before you leave for your break. if you have no ammeter, that's fine someone else can replicate and test if you post your cct.
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
wattsup
@Jacob
Thanks for pointing that out. Actually it's not 52 but 24 vac. I looked closer and here are all the pictures which I have now indicated as Trial 1 to 5 so we know how to refer to them. I call them trials because I am sure Brnbrade has some more tricks up his sleeve (or his t-shirt). lol
Five variations have been shown thus far.
Trial 1) Coils + Magnet + Cap + 3v Battery, DC-DC 13 vdc out.
Trial 2) Coils + Magnet + Cap + 3v Battery, DC-DC 24 vac out.
Trial 3) Same as Trial #1 - Magnet + Sound (two channel positive only) DC-AC 250V out.
Trial 4) Coils + Cap (330 uf 200v) + Cap (62 pf or uf(hard to see) 400v about 4-7v ac out
Trial 5) Coils + 4 Caps (hard to see values) about 20v ac out
@all
If any of you have figured out any of the other cap values, please refer to them with the proper Trial #. Please let me know if there are any other mistakes.
Also, you guys should stop asking Brnbrade for this and that and just concentrate on what there is. Gimme Gimme never gets. The guy needs a break to bring this up to par so we have to give him some slack. Complaining about it will not work.
Oh yeh, I found two nails? Now I can start building. lol
Earl
Hi All,
I am a believer in galvantic separation of the output coil(s).
In this case make another winding over the other two windings, few turns for low voltage, more turns for higher voltage.
I suggest two identical output coils, one over each rod, connected in series for more voltage or in parallel for more current.  This would give identical load for each rod.
Want 12V to charge a battery and 220V for the fridge, then wind 4 additional coils, two on each rod.  Rectify, buffer, and convert as necessary.
Don't be afraid to experiment.  If Brnbrade and Sugra can have intuition, so can YOU.  Take off the horse blinders and start building instead of asking for more details and a schematic.  See my signature below.  Destiny helps those who help themselves.
Don't think it will work?  Then build Aspen's idea of concentric cross-over capacitors and ignite the thing with a spark plug and HV coil.  Document your research and post back to the forum.
Prefer to build SM's TPU, fine do it.  Prefer to try your own idea, fine do it.
Regards, Earl
Earl
Hi All,
when winding the aluminum layer be careful and pay attention what you are doing.
You may have to do this several times because:
Aluminum layer can be wound with more than one turn, start shorts out the end.
This gives a low impedance one-turn short circuit.  This is usually regarded by Engineers as a no-no.  In this case, who knows?
Before reaching the start point again, insulate the second layer from the first so there is no short circuit.  Pay attention that nowhere does the second layer make contact with the first.
Experiment and tell us your results and effects !!!
There are FE rumors that alternating layers of aluminum / insulator / alu / insulator / right next to each other ........  can have good effects.  So another experiment is instead of just one wrap of alu foil, try a multilayer sandwich.  There is a rumor that glass as an insulator in such a multilayer wrap is beneficial, in this case try to get some glass fiber wallpaper to use as insulation.  DIY & Baumarkt usually have glass fiber wallpaper.  Or just use whatever you have.
Regards, Earl
