The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
BEP
We all know you can light a bulb with unusual low voltage if that voltage is pulsed and coil actions increase the voltage. The key part was 'pulsed' which implies to most that it must be switched to have the effect.
The very first radio detector had no such switch/diode/rectifier. It was an LC circuit by Tesla and others with different variations. Circuit-wise that is what is going on here. The current is indeed being switched. You must also consider the capacitance factors introduced by the method of layering. So basically I'm saying that you can have the same effect as an active switch by using a passive circuit. Tesla did it with his magnetic rectifier and his regenerative tank receiver. And guess what - with the right arrangement there is nothing faster.
The thing that usually becomes apparent is that the Watts aren't there. i.e. the voltage drops to almost nothing when a low impedance load is applied.
I urge you all to not stray far from BrnBrade's construction until you understand how it works. When you do there are improvements and ways to enhance.
Knowledge is useless if there is no understanding and constructive application.
I'm sure when we saw our first spider some ran and others bowed before it and sang mantra's. Now we just step on it. All for the same reason - we don't understand.
If the spider had self-awareness he probably thought we were idiots  ;D
(NO disrespect intended for anyone's beliefs! I DON'T know it all but I try to learn)
As far as TPU/Pipes. I have already found that precise control is mandatory and I already know that both are one in the same. Either way we are creating a set of highly interactive toroidal fields.
Building these coils will be very instructive for those that apply the lessons to the SM device.
Good Luck ALL!
z_p_e
Y'all saw Daves videos of him lighting bulbs with a small TPU-shaped device?
How large do you suppose those batteries were inside it?
I'm just amazed sometimes how folks will rationalize this or that, when if they just took a step back and pondered things for a moment, they'd perhaps see things for what they are...or aren't for that matter.
As long as we're all having fun :)
I hope our friend has cracked the Cook coil as he seems to be saying.
As there seems to be a few building this thing already, what are you all using as your reference to wire it with all the components?
Surely one of you builders out there could redraw (and post) the entire device as per your own build? I'm sure it would be much appreciated by all.
Bruce, how is your build coming?
Darren
Bruce_TPU
Quote from: chrisC on July 03, 2007, 02:26:02 PM
Quote from: btentzer on July 03, 2007, 02:17:15 PM
@ALL
I will no longer post any more "Theories" of operation on page 1.  Only build information to assist replication.
Happy Days!  :)
Bruce
@ Chris,  Thank you...Kind of!  LOL  Please reread BOLD above.  Thank you!  Cheers.
Hello BEP,
@ EVERYONE
I concur completely with BEP on this.  Build to specs first.  Then try to understand.  Then "size it up!"  My favorite part!! ;D
Happy Days!  :)
Bruce
hartiberlin
Quote from: jacob on July 03, 2007, 10:20:06 AM
Quote from: z_p_e on July 02, 2007, 10:59:40 PM
It would not be too difficult to power a 12V, 50W bulb for a few minutes from 2 AA batteries with the right circuit. Keep that in mind folks.
Darren
Darren,
I need your help here. I have no idea how this would be possible. Because it would imply pulling upward of 10-15 amps from those small batteries and maintaining that draw for a few minutes. Plus, let's keep in mind that there is no high speed switching component being used here. Can you please explain how it can be done. Thanks!
Jacob
Hi ,
I tried a while back what current you can get maximum from
a AA NiMH cell when you use a digital meter at the 10 Ampere range.
It showed a shortcircuit current via this meter of 5 amps maximum.
Unforunately I did not measure the inner resistor of this digital ampmeter
and also not then the voltage at the cell,
but let?s say, you have one of the newest AA NiMH cells and they can deliver
1 Volts at 5amps then that will just get you 5 Watts,so 2 cells would only get you at maximum
around 10 Watts and brnbrade?s lightbulb looked a bit brighter than that.
Bruce_TPU
Quote from: z_p_e on July 03, 2007, 02:32:58 PM
Darren
Hi Darren, and I am glad you asked... :)
My ECD is finished. Wired and the circuit soldered as of last night.  (Thanks to my partner).  Tonight we experiment with it for the first time.
Also, tomorrow I look for some scrap AL tubing to cut, on my farm.  I have a bit of everything every where.  I have the wife and son taking a large old speaker apart today, to salvage the magnet.
And me... I am at work!  ;)
How is your build going Darren?  Will it be real or simulated?  (Kidding of course! ;) )
Happy Days!  :)
Bruce
