The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
brnbrade
Bruce_TPU
Hi brnbrade,
Please let everyone know what size bulb that is, 10 watt, 40 watt  60 watt,?
Also, that bulb is lit while the stereo is hooked up, correct?
Thank you for details my friend,
Bruce  ;)
supersam
bruce,
the first consideration for my questions was for brnbrade's safety!  one of my concerns is , brnbrade creating a capacitence, like bob's, that could potentially go into an avalanche cascade and create that sudden "kick" that could cause a tv to implode or "a lightning strike!"  since brnbrade's preliminary results show that it is possible to convert through two transformers the results that have been documented, there are several considerations, safety wise that should be looked at first!  maybe everyone should take a second look at these before pushing for answers to questions, from a youth, that they may be better equipped to answer.  sorry if this seems like a step back, but, sometimes it might be warranted!  no disrespect intended to our young friend that has published his results!!!  THANKS TO BRNBRADE AND TO YOU TOO BRUCE!!!!
i think all good things come.
lol
sam
supersam
brnbrade,
shuttinup shuttinup!!!!
looks like you know what your doing!!!
lead on!
lol
sam
bob.rennips
Quote from: Earl on July 01, 2007, 03:47:41 PM
Hi Jason,
From the patent text, it is clear that the more you break the core up into smaller and thiner wires, the better.  It appears to me that a massive, solid core is the exact opposite of what you want to do:  many fine iron wires as core.  Fence wire maybe.
Regards, Earl
Quote from: Jdo300 on July 01, 2007, 02:06:57 PM
Hi Earl,
My setup only has steel cores on it. 1018 if I remember right. The coes are 2" in diameter so I never tried to find magnets that big to replace them with  :D.
God Bless, Jason O
How about using sub millimeter pellets or grinding particles packed into a perspex tube.
