The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Dingus Mungus
WOW! That looks a whole lot easier than the more common TPU design... Being that its not a torroid and all. I hope a schematic will be released soon. I'll definitely replicate this and attempt to confirm your results. Also I have the equipment needed to get a output wattage reading. Thanks for posting your findings here.
Good luck and thanks again,
~Dingus Mungus
Bruce_TPU
Hey guys,
The pictures are pretty clear.  If someone would be kind enough to draw and post a circuit and aprox. wire sizes, and then post it for brnbrade, if would be helpful.
There are two identical coils it would seem, not one coil as I first thought from his original posts on EM's thread.
Also know that the big black round thing is a large magnet!
Thank you,
Bruce  :)
Bruce_TPU
It also looks like the thin wire is wired in mobius fashion on both ends.  If someone can confirm this looking at the picture?
Brnbrade, is there mobius on both ends?
Bruce_TPU
There is a definate mobius on the thin wire on both ends.
Brnbrade was a student of Erfinder also. Brnbrade does not speak English well.
So we have coils
Large Magnet
oscillations
Mobius on both ends
DC Input / AC Output
Large voltage output
Unknown amperage
Brnbrade is going to hook up a light bulb, and take a picture.  He is also going to borrow an amp meter.  I do not know when this will be done.  I for one am facinated.
The red wire appears to be 12 awg solid.  The thin wire seems to be braided.  Someone else will need to give type and size.
Cheers,
Bruce
Mannix
Bruce,
HMMMMMMMMMM........This ..in Steven marks tpu thread??
"that aint no tpu in there son ......I say it just aint!"
I like the fact that there is no digital meter....
Im looking foward to being completly surprised...No, astonished!
Lindsay Mannix
