Talking about phase...
Started by bob.rennips, July 01, 2007, 08:16:56 PM
Bruce_TPU
@ Grumpy
I vote one of each.  LOL
Never a good thing to have all or our eggs in one toroidal basket!
@ Bob Boyce
Pictures would be helpful of course.  Is there a formula you have worked out based on diameter of the core, or say primary to secondary winding?  Or would that same formula be the same regardless of diameter, but simply the length/amount of wire would change?
Warm regards,
Bruce
Bob Boyce
Quote from: Grumpy on July 07, 2007, 07:51:49 PM
hmm - iron core or air core - hmm - decisions...decisions
I was gonna say try both, as toroidal power systems can be be made in many ways, but Bruce already answered that while I was typing this.
Bob
Grumpy
CCW was my first guess.
Your winding arrangement - being circumferal - produces more than just a rmf.
The number of poles might effect the pattern of he standing wave when the shift occurs - have to think more about that.
winding...
        -Frank Edwards
Grumpy
It's wound.
Not sure if I want to use a ring counter or my two freq gens to drive it.
        -Frank Edwards
giantkiller
Well put some pics out and parade that beauty down the promenade!
--giantkiller.
