Talking about phase...
Started by bob.rennips, July 01, 2007, 08:16:56 PM
gn0stik
Silver coated ezflow wire can be found in high end automotive audio stores.
Bruce_TPU
Hello all,
Here are some sources for silver plated copper solid wire.  I would suggest not ordering yet, until we have a gauge or suggested range of gauges, as it is very pricey.  Unless money is no matter to you.  ;)
Thank you Jason and Grumpy for your help in sourcing this information:
http://cgi.ebay.com/CRAFT-30-YARD-OF-24ga-SILVERED-WIRE-METALWORK_W0QQitemZ8174749479QQihZ 020QQcategoryZ41224QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
http://cgi.ebay.com/Silver-Coated-Beading-Wire-Tiger-Tail-38mm_W0QQitemZ220131859114QQihZ0 12QQcategoryZ67718QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://www.alphawire.com/pages/254.cfm
Mil spec number for Teflon coated solid copper wire with silver plating is MIL-W-16878 - Google this and you get plenty of hits.   This place carries it:  http://www.weicowire.com/specpage.asp?nGroupID=190   I recommend searching for surplus - stuff ain't cheap.   PTFE is "Teflon".  FEP is very similar compound.  The silver plating is what matters.
Super God
Quote from: starcruiser on July 19, 2007, 01:01:16 PM
Quote from: Super God on July 19, 2007, 10:21:01 AM
I've taken pictures of mine, it's all wound and everything, the collectors, bias, and controls.  Just figuring out a good oscillator plan with the tubes I'm going to order eventually (money issues)
Why not try a simple blocking oscillator design using a small torrid from a PC power supply and tap that for your open ended primaries? I recall reading that you can build 2 blocking osc and have one track the other and by adjusting the time constant of one you can create a simple frequency divider which is sync'd.
here a a couple of sites that might be interesting to review.
http://139.134.5.123/tiddler2/c0508/block.htm
http://home.att.net/~pldexnis/CTC2_how_it_works/blocking_oscillator.html
http://www.vias.org/eltransformers/lee_electronic_transformers_11_01.html
http://www.electronic-circuits-diagrams.com/psimages/powersuppliesckt6.shtml
http://www.du.edu/~etuttle/electron/elect37.htm
I don't understand the blocking oscillator.  Could someone explain what it would do?  Does it just block out the negative cycle of a wave?
>9000
Bob Boyce
Looks like my open posts here need to end. The water for fuel crowd have begun to link here in the misguided impression that the RMF device is the same as the lower energy version that was designed specifically for the waterfuel application. I do not want to be responsible for encouraging the wrong kind of experimenters into dabbling with dangers they do not comprehend. I was afraid that this would happen. Those advanced enough in the art to experiment safely with this can continue to communicate with me via email or PM.
Bob Boyce
Grumpy
        -Frank Edwards
