Magnet motor by pcockriel
Started by hartiberlin, July 04, 2007, 07:17:52 PM
pcockriel
Can I upload Video On overunity?
working on the elemntal rod.
I slowed down the volts to .002  with wire wraped around strong magnets and placed in a copper tube
the light stays on, and somehow the power in the battery is
not changing. I think he used a very small battery and slowed the voltage down and the light stays on with less volts ,watch his video again and if you look very very close you will see that the rods are copper,
and I can tell this because I do Plumbing and the cap matches a 1/2 inch copper cap thats not sold anymore with that little point on the cap the new caps are flat on top,also I have 16years background as a
plumber , anyway with a 14.5 volt dc battery the meter read 13.91 and after placed
in the tube dropped to .002 volts. I couldnt believe it. but I figured out what he done ( i think) and I have to set it up so there are no loose connections and see how long it will run, if it runs over two days I will post the results..
Can We Upload video on this site? I dont want to post it on youtube and explain it again
gyulasun
Quote from: pcockriel on July 06, 2007, 08:03:11 AM
Hi,
Yes you can. By clicking on the REPLY button a POST REPLY window appears and under the main Text window you can see Attach:  in bold and by clicking on Brewsing in that same line before (more attachments), you will have access to your own hard drive folders/files. When selected and also finished the text, click on Post.
Gyula
Earl
Hi Paul,
here is how you upload a file.
You can always stretch a window by pulling on it with the mouse.
Pull somewhere on an edge or in the corner if you want the window bigger.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Earl
Hi Paul,
try to make the video as compact as possible.  Don't waste time, show things quickly.
Music not so important as talking and explaining.  Make as short as possible.  Try to keep down to 5 or 10 MB, since I don't know if overunity.com would have a problem with a big 50 or 100 MB file.
Be efficient when filming.
Have fun with your experiments.
Regards, Earl
huhh
Quote from: pcockriel on July 06, 2007, 05:24:05 AM
Wow sad news guys the spinning ball has balanced out and stopped we are running into a problem the iron has turned into a magnet and now repels and balances out. sad sad news
Dang, I was just thinking about it doing that yesterday.
But how long did it spin before becoming magnetised?
I think you can use a dc electromagnet to demagnetise the ball.
Maybe need a ferrite hollow ball?
