Magnet motor by pcockriel
Started by hartiberlin, July 04, 2007, 07:17:52 PM
hartiberlin
Guys, with the nails in the trees you will kill the trees. You get voltage, but no current. There are the saltwater batteries even better. Let us just concentrate on Pcockriel?s magnet motor and his new experiment with the wire around magnet sticked into a copper pipe.
Thanks.
MeggerMan
@Pcockriel,
Stefan is right, forget knocking nails in trees, you need to focus on your magnet stack idea and copper pipe and the ball in a cup.
Tell us more about these two set-ups.
Rob
MrMag
Furthermore, copper nails in trees will definitely kill them. When you want to get rid of a tree stump, you drill holes in the stump and then pour copper sulfate in the holes. It will rot the stump.
Tim
Freezer
Don't worry I gave up on that as it probably does have adverse effects.  I also tried a fruit and got a volt.  I then used only water and got similar results.  I then used those plastic containers used to store small items like fishing lures and put in series and parallel the same setup.  I got about 3 volts.  Still not enough amps but it does barely light a led.  Just a fun project.  Don't worry, no other living plants were hurt in the experiment :D  I adore nature too.
TheOne
i was wondering if I will get a lot of volt if put nail on my rats ? :)
