Thanks to ALL for your help!!
*The Study of the Practical Mechanics for a Working TPU*
Started by Bruce_TPU, July 05, 2007, 12:52:53 AM
Bruce_TPU
Hi Mike!
I do like your coil.  It looks very nice with the plexi, nice touch!  Now, wire it to give you a three phase RMF, plug in the three sisters and watch that baby go!  Take another pictured when wired!
Cheers, ;)
Bruce
Motorcoach1
@ Bruce Thank you much thought went into this , It can be disassembled in 10 seconds to reconfigure the model . could you email what you have done as per the coil set up and driver schematic ?        @BEP is there a chance that I could get a file on your Model to play with ?  I have sq plates in aluminum 3/8 , steel.3/4 , stainless steel 1/4 mmmm copper ? I'll need some i guess heheheh this is fun !  Capacitors ?
BEP
@Motorcoach1,
You'll be one of the first. I'm creating the -so demanded- documentation. I don't know how much that will help some but I'm making sure it is not cryptic or convertible into Sanskrit stanzas. I won't bother adding theory of operation. That wouldn't be read unless it was posted by someone else.
weri812
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
