Saying Hello!
Started by lincolninked, July 08, 2007, 12:57:50 AM
Does Pulse Wave Electrolisis Exist?
Yes, I have them available at my garage sale.
3 (33.3%)
Yes, but I can't remember where.
0 (0%)
Pulse what?
1 (11.1%)
Who wants to know?
5 (55.6%)
Please don't hurt me!
0 (0%)
Mommy!
0 (0%)
Total Members Voted: 9
IronHead
You can see the same effect in my hot ratty open cell here.
This one is just a little bit bigger and alot more water.
The Cell idea here is to have modules
that can be scaled to any size.
http://www.youtube.com/watch?v=svukDnceeRE
That last one you posted is impressive . any idea of the amp draw?
Also that last Cell sound like it is pulsed . The high surface tension gives
it a nice look on the output as well. You dont get that in a KOH cell ,
the bubbles burst  almost instantly.
http://youtube.com/watch?v=vIOJlALu1pw
lincolninked
http://www.gethydropower.com/faq.html
This cell is one of the most "polished" units out there.  For their prices, it had better be "cute".  Beyond the cute and polished aspects, it is a serious producer.
Watch the animated cell being built in my post above.   Then watch and listen to the men talking about the browns gas machine.  There is where the rubber meets the road!   I do not fully understand why they use one volt per cell, but it puts off enough gas to cut/weld steel which is much more than required to run an automobile.
lincolninked
Correction, this is what I tried to post as an animation of a cell being built.
This is of a browns gas generator to cut steel:
http://youtube.com/watch?v=rgIgpSwlExA&mode=related&search=
Machine is here:
http://youtube.com/watch?v=JrP8s6xB8Sg&mode=related&search=
Listen to the men tell how it works.
IronHead
EDIT
"but it puts off enough gas to cut/weld steel which is much more than required to run an automobile."
This statement is not true . Sorry but that is the facts as far as power consumption goes on the BrownGas welder.
Ah yes I have seen this brown gas system. A series and paralleled big cell stack, and the other anima you posted a few back as well.
My series cell is similar but with no gasket, the  walls of the cell housing are slotted to seal the plates in.
I found that there is much more to volt tuning than the "2 volt no matter what" deal.
Plate spacing, surface area and over all design of the cell stack itself. Some Cells have their plates so close there are actuality arcs between plates you don't even see happen, Plate shorting .
I am not sure about the Gorilla just yet . I know some people that bought one and they say that it has an air pump . But I just don't know at this point I do not know the intentions of the user. He called them about the pump and they told him it was to make the gas safer  with mixing the air into the cell .
Anyway  what are you working on now ?
Can you show anything you have built so far or in the process of building?
lincolninked
I will be putting a two 7 plate design (business card size) in my 2005 Ford F-550 6.0 diesel this week, if time allows.  My ford is 12 volts x's two batteries. or 24 volts.
I will have one unit of seven cells at each battery. Final plate design comes back from the machine shop Monday.  I wanted to xnay all internal wiring. So the final design is 100% stainless plates in the explosion friendly chamber.  Plates electrical design similar to Hydrogen Tap later models but with smaller heaver more efficient plates. .0062 316L.  My plates sit in only 25% of the water in the chamber with 75% of the extra water over them.
I am a little concerned the water layer of 3 to 4 inches above the plates will hinder the liberation of the hho.  I will monitor this and use something to break the surface tension as needed.  Possibly a small amount of acetone if the Lye is not enough to do the job.  I have discovered the gas produced is more usable the sooner it is made, so all lines will be kept to a bare bones minimum. I will be using a system of vacuum lines to give the cell a constant vacuum of 16 or better at all times.  The temperature of the unit will be maintained by the cool side of the radiator.
The system is self starting by a vacuum sensor that turns on the system.  No vacuum, no hho.  I will use several check valves as well as two bubblers (again, worried about the water stealing back my hho.)  With two complete separate systems, I am assured better overall performance by having two systems.
I do not do videos posted to the net very often, so do not look for pics real soon.
