Magnetic imbalance wheel
Started by vikingdread, July 09, 2007, 05:17:46 PM
mapsrg
rebellz...is this your setup?it looks like it can be adapted ...the concept illustrated had merit....done this as well but not as professional looking
mapsrg
my version.Magnetic Gravity Wheel.Smaller wheels mounted on a larger wheel and repelled into paths by magnets so as to cause a continuous imbalance.2 are fixed repelling magnets .1 are repelling magnets mounted on small wheels.T are the position the smaller wheels rotate due to repulsion and cause continuous unbalance.Small wheels @100-200 diameter depending on number used.P is the path taken of rotated smaller wheels as the larger wheel rotates.
wattsup
@vikingdrea
Just to give you some other ideas, here's one concept I drew back in Nov 2006.
But my next idea is what is catching my interest. This idea uses normal available linear motion devices and control. I think this idea deserves a look.
If nobody does this, well, one day, when I have time, I will make my Linear Motion Wheel. Again I'm so sure this will work, that if anyone can do the consumption estimate using 40 lbs per bar, I would be curious. I will be using 3 linear motion bars. Imagine 3 separate lines cross-crossing at 60 degrees with the ability of immediate displacement of a weighted platform. The linear motion system can move up or down with very heavy loads. So imagine such loads at a continuous imbalance. The linear motion can have infinite positions of weight extension or retraction thus providing a variable motive force. The question would then be can linear motion displace enough weight to turn a generator and produce more power then the wheel will consume. Or put another way. Could I get more than 1 hp out of the shaft with less than 750 watts.
The linear motion type as drawn and animated below requires only activation at 6 o'clock until it moves upwards and I figure it must be held for 12 degrees thereafter per the rpm rate. The drawing is simplified to show an outer support structure would be from the outside and each linear motion shaft would be separate and angled at 60%. All you would require is three linear motion bars to do this.
I think there is some merit to this idea. A fully controllable rotary motive force without any BEMF. Or very little. The efficiency per HP produced should be good.
But again this is only at concept stage.
ring_theory
Ok. fine works guys.
I can only see one thing that might assist this idea. Ok gravity flows vertical. strait down. one thing i see the same in all of these is that the repulsing side magnet is lined up to oppose the moving magnet it is repelling strait on like this S---N> <N---S. This only uses the repulsion to repulse it on it's shaft directly away. were on a moving radius and in essence we are just sliding weight to a position where it is least resistant to the other side of the fulcrum. Lets say we assist the lifting by placing the magnet vertical as to oppose gravity while repulsing it to the desired location. this should make these systems usable, centrifugal forces will return the
inner magnets to the outer ring of device no need to pull or attract them. one side of the wheel is gravity powered the other is repulsing up and in. changing the fulcrum of the lever.
@vikingdread
add another magnet between your existing two and go vertical with the three driving magnets and get rid of the attracting magnets.
@RebeLLz
same advice tip your opposing magnets vertical and get rid of the attracting magnets. Add more sliders and longer slide. i also think this setup could be downsized. it must weigh a ton?
@mapsrg
Caged? if this was like a caged bearing and the balls were magnetized with shorter opposing magnetic fields on the inner and outer ring as to tumble the fields of the ball bearings. It has the potential to be a planetary motor!
@wattsup
all that blind sided me and that's hard to do! You rock! i like the addition of springs. however the same advice applies. vertical and remove the attraction side.
Basically what your doing with the springs are affirming what i would term a "centrifugal moment". What the drive or opposing magnets are doing is interrupting the centrifugal moment. This one will likely self start and resist a load as well as work on a horizontal plane.
@ all
great ideas! If you have problems with it running a short period and then you lose the centrifugal moment. reverse the fields of the opposing magnets and sliders. if your currently using N to N switch them to S to S. The planet is a big polar magnet gravity is the result of it. gravity will reflect the corresponding pole.
Good luck in your en devours 8)
P.S Be careful!! Be prepared for flying parts! build it triple redundant or don't build it at all! THINGS HAPPEN VERY FAST IN MAGNETICS!
mapsrg
not caged.in the diagram the smaller circles are smaller wheels or discs mounted on a larger wheel or disc.these are repelled into a path that results in imbalance by external magnets,2.
