help with my Newman machine
Started by Peacemaker, July 09, 2007, 06:09:23 PM
Jason
Correction 30 degree not 30% .
hartiberlin
Jason,
I meant not have it full on the whole 30 degrees, but pulsing it during
these 30 degrees.
For the same torque output you will need then higher
input voltages but you get a lot more RF bursts this way.
You can also energize the coil
from the battery for around 100 degrees,like
10 steps x  10 degrees.
So 5 degrees on and 5 degrees off
would be one step.
Repeat this 10 times,so you have 100 degrees.
The rest 260 degrees of the circle the coil will not be energized.
Put this 100 degrees connect-disconnect commutator into a zone,
where the coil attracts or repells the magnet the most and you will
have contineous rotation and many RF burst spikes,
which can pretty easily light up incandescent bulbs in series
with the coil.
Jason
Stefan,
I am going to investigate whether a electric fence commutator will work. They pulsate, I just do not know if I could figure out a way to accelerate the pulsation. One idea I had was to fix a flexible bearing next to the magnet rod which has the commutator connected to it. Then on the rod attach little wires all around it. Do you know what motors or machines have large magnets in them? I want to go to a junk yard or industrial yard to find some huge magnets to build a motor with more torque. Another quick question. Do you know where I can get a simple breakdown in dummy terms of the rotoverter? Thanks, Jason
Magnethos
I have a question about the motor and the position of the magnets:
What is the correct model? A or B?
Chad
@magnethos
Model "B" is the correct configuration.
Chad.
