Spinor resonance -- explanation for TPU like devices
Started by MarkSnoswell, July 14, 2007, 09:17:10 PM
Super God
Wow this i s really somthing, my coil right now is 3 collectors with three controls each wound 120 degrees or so around the collector itself.  The collector is very thick wire.  A total of 9 controls to pulse, if I can get SOMETHING with one control, I'll just connect them in series to add up the potential and hopefully something good comes out.  This has me VERY optimistic!
>9000
tao
Mark,
You have probably seen what is below, but..... :)
More and more, we keep seeing, at least I do LOL, devices where you have a complex mix of DC and AC in the SAME conductor, and somehow apparent OU effects appear. There is also a common thread linking in harmonics too.
I know this has been brought up long ago by z_p_e aka Darren on another forum, I just felt it was good to post because it is highly related to the things that Mark has been so eloquently putting forth.
http://www.kz1300.com/hfgc/
Here is an excerpt:
"BACKGROUND OF INVENTION:
It is known that coppers' electron mass at rest is M=9.107 x 10? ??.  It has odd electrons and is paramagnetic which exhibits magnetic resonance.  The magnetic flow in copper brushing the atoms causes atomic vibration which, in turn, produces a ringing effect.  When superconductivity is in place, agitation of the atoms is prevented.  This allows voltage to flow freely because there is little or no atomic vibration; thus, reducing resistance.  Magnetic resonance is a phenomena exhibited by the magnetic spin system of certain atoms, whereby the spin system  absorbs energy at a a specific resonant frequency when subjected to an alternating magnetic field.  The key factor is that the resonant frequency aligns or stabilizes the atomic vibration much like superconductivity does allowing the atoms to remain in the same place.  Likewise, harmonic radio frequency produces the same desired effect.
PROBLEM:
The transmission of electricity using a medium at room temperature is hampered by thermal resistance caused by the mediums atoms oscillating at an unstable rate.
SOLUTION:
By arranging the atoms in synchronous alignment, the transmission of electricity can be accomplished at room temperature without thermal resistance.  Radio frequency oscillation aligns the atoms by using an external jacket that surrounds the medium which, in turn, magnetically aligns the atoms allowing the free transmission of electrons.  Theoretically, another way to align the atoms in a 60 Hertz signal is to ride the sine wave similar to the way noise travels.  The high-frequency signal piggybacks the sine wave and aligns the atomic structure by magnetic waves.
DEVICE:
This $350 working DC prototype utilizes high frequency, high voltage in a manner that feeds back on itself.  That is to say, this device uses small amounts of voltage to produce large amounts of energy.  The unit works off of 24 VDC that feeds an oscillator producing 2 kV.  This feeds across the capacitor and the neon gas bulb.  In tests using a 24 VDC battery to feed the oscillator, on one side of the capacitor (-500 VDC) was produced, and on the the other side (-430 VAC).
An oscilloscope showed 1.3 volt peak to peak wave feeding the DC side.  This by itself was not enough power to maintain the system for long periods of time.  However,  when the wave fed the positive input back into the device, the energy increased.
High voltage output, either positive or negative, is not normally fed into the positive circuit of a lesser voltage because of thermal degradation due to the resistance.  However, when the RF and the voltage are harmonically aligned there is no creation of heat.  This unique aspect allows the system to feed back on itself.  Tests prove that without the positive feed, the circuit depletes itself within a matter of minutes.  With our design, the same circuit will run for months without draining any noticeable power from the battery.
(Fig. 2)  shows a multi wave oscillation.  The first pulse wave consists of 5 oscillating waves at .5 volt positive to .8 volt negative with a 35 microsecond spread.  The wave length is approximately 1000 meters.  This wave propagates through the batteries allowing less drain from the load.  The second pulse wave duplicates the first. Note: At 500 MV to 800 MV there is not enough energy to produce a change at the moment of use.  However, with no load this would take hours to recharge the batteries.  This substantiates that the device is not recharging itself, but allowing a harmonic stability to provide less resistance from moment to moment.
(Fig. 3)  shows the negative battery wave to be 10 times oscillated signal at .10 volt peak to peak from zero reference at .6 volt positive to .4 volt negative with a 35 microsecond spread.  It is noted however, from Fig.2 to Fig. 3 there is a noticeable .03 volt peak to peak difference.
POTENTIAL:
In the power generation industry, this device should allow a greatly reduced resistance factor in the transmission of electrical energy.  It would substantially reduce the amount of "force" needed to transmit electrical potential from one source to another.  The amount of energy needed to complete a circuit is decreased because of the positive feed.  Other industries interested in this technology would include all manufacturers of electronic devices in telecommunications, computers, consumer products, etc., and of course the military complex!  (Presently, this device has been tested and proven in DC, and is theoretical in AC.)"
Ok, and here is a video of Mr. Walt Myers, a rare one, I spliced it together...
http://video.google.com/videoplay?docid=7002680083998323828
I just thought it was all interesting, I thought it was interesting last year, and I think it is more interesting now, considering some of what Mark has been saying. All knowledge is good knowledge right? ;p
Oh, and here is a good post by Dave(ctglabs) from another forum that relates to Myer's/SM's device....
"The more I think about it, the more I like this theory!
First of all, way back when on OU.com we all talked about magnetic induction, a logical first step I guess, until we looked closer when we got the coil configuration and realised that magnet coupling was at a minimum due to the orientation, then we saw some electrostatic coupling, which was another logical step in the absence of magnetics.
As you say, he say "excitation" of the collector. This doesnt have to mean the electrons, but the atoms too. Indeed the coils wound over it are like the coils wound over an iron rod, the best way to get overall coverage of all the atoms. So its in the worst place for induction, but the best place for effecting the "material itself".
Could the weight loss and the interial feeling be due to the diamagnetic effect? Any magnetic field will be repelled by the superconductor and always maintain the same distance as long as the strength of the field doesn't change. As the thing pulses this state on and off, it will want to try and maintain a certain distance from the earths magnetic field each time and will attempt to resist movement in any direction.
Also, if the material can be brought down from resistive to zero resistance, can further excitation bring it even lower, in to a true negative resistance state at which point IT WILL SUCK ENERGY IN FROM OUTSIDE, converging energy rather than scattering it, time reversal in action?!
Regards,
Dave."
z_p_e
Quote from: tao on July 17, 2007, 10:47:50 AM
Mark,
I know this has been brought up long ago, but since I am the one who did so, I will do so again, because it is highly related to the things that Mark has so eloquently putting forth.
LOL. tao, perhaps tpu fever has affected your memory somewhat. Actually, I was the one that posted this publicly at gn0sis, and in fact I wrote up a rather long and involved theory based on the Myers device....remember?
QuoteOh, and here is a good post by Dave(ctglabs) from another forum that relates to Myer's/SM's device....
"The more I think about it, the more I like this theory! .....
Regards,
Dave."
This was actually Dave responding to my theory in my thread.
No offense intended, but duely afford some credit where credit is due my friend :) I have done so for you on more than one occassion.
Cheers,
Darren
Bob Boyce
@Mark
It was great to see you mention the open ended primaries. I have been trying to convey exactly this concept to one of the replicators that had it in his head that more primary current was the answer. When I told him that the primaries (control coils) could even be fed open-ended with potential, he seemed to think I was nuts! I had to explain to him that in order to do this, the power FET driving the open ended coils would have to be loaded in order to be able to dissipate the pulse potential as quickly as possible. This is the reason I just complete the DC path through the primaries, as it can be so much easier to do, as long as the drive pulses can be kept short enough to switch off before much primary current can begin to flow.
You are 100% correct in that the higher the DC bias potential, the greater the energy gain possible. The only reason I limit to the 160 VDC region in that common unit is because it is the voltage requirement of the load that unit was designed to power. By the way, I had that same replicator run a test by installing a DC blocking capacitor in series with a 120 volt load, raise the DC bias potential, and watch the output climb while no additional load was placed on the power supply. I think he finally may have learned something about the potential of DC potential ;-)
Have you tried spinor resonance modelling with the use of x, 2x, 4x phase controlled drive frequencies. I am curious about what it would predict?
Bob Boyce
tao
Quote from: z_p_e on July 17, 2007, 12:22:46 PM
Cheers,
Darren
HAHAHA, maybe it was you. Ok, it was Darren! But, still, it's viable, so I will just edit my post.
But, since your posts are GONE, HAHAH, it was hard to verify ;)... No hard feelings or offense, of course...
I did find the video and splice it up though, on gn0sis ;p
