Spinor resonance -- explanation for TPU like devices
Started by MarkSnoswell, July 14, 2007, 09:17:10 PM
MarkSnoswell
Quote from: BEP on July 26, 2007, 09:25:21 PMA circle isn't really 360 degrees - is it?
In our 3(1) universe you can walk around a circle -- you can get a particle to travel around a circlar path if it remains oriented the same way ... these are 360 deg rotations. *BUT* if you rotate a particle around 360 deg you are only half way there -- you have to rotate it another 360 degrees to get back to the start. In doing this 720 deg spin the particle is forced to go through rotations in all three dimentions.  (there are an infinite set of 3(1) dimentional spinors that have any multiple of 720 deg)
This is they key -- roatation is a phantom, it's a virtual relationship between things -- a mathematical construct. Rotating fields and rotating machines are boring -- they are 2D things that happen to sit in a 3D world. We want to travel into new teritory and explore what happens when you play with spin = rotating things in 3 dimentions at the same time.
@not_a_mib
Great theory -- really bad rap ;)
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
MarkSnoswell
Quote from: Grumpy on July 26, 2007, 01:10:45 PM
Wilbert Smith had a nice way of explaining things. http://www.rexresearch.com/smith/newsci~1.htm ...
Dave Lowrance has studied the work of Wilbert Smith and performed man experiments.
Dave's page on the Control Fabric with images: http://magnetism.otc.co.nz/ControlFabric.htm
Study will show that the Work of Dave and Wilbert Smith can be correlated to that of Walter Russell.
Time flow rate - or rate of entropy - increases with density.  So, by increasing pressure, or torsion, we increase density and the rate of time flow or entropy.
I get the feeling that these are going in the right direction -- very different words and expressions that I would use but in the right direction.
My interest in theory and concept is only as a tool for intelegent design and engineering of new devices to make our lives easier and to make our environment better. Too much theory becomes a self sustaining reality in it's own right -- but it wont pay my heating bills or replace fossil fuels ;)
cheers
mark.
Dr Mark Snoswell.
Earl
Hi Mark, hi All,
Let's define some 3D excitation for the vectors
AB, AC, and AD and start building.
TAO thinks the control coil excitation without current flow causes an electrostatic charge to be transferred to the collector; a weak vector BA followed by a much stronger vector AB.  The OpenTPU has two magnetostatic biases, say AD or DA.  Mark has said he doesn't think my electrostatic field is correct, but should instead be connected gavanically to the collector.
Let us have a brain storming and decide what should go where.  It is time to start moving the pieces of the puzzle into place and then warming up the soldering iron.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
bitRAKE
@Mark,
regarding the tetrahedron with the loops on each face - what signal could be present in each loop and be mutually supportive? Some rather complex environmental conditions I could not wrap my head around.
The animation is more along the lines of what I've been pondering. Supportive signals that modify/contain the potential within the structure. I'm not flirting with Maxwell's demon - at this time I'm just trying to maintain a field difference with minimal energy input.
If there are structures complementary to "nature" then COP>1 should be possible.
Energy might not be FREE, but the universe has been building it up for billions of years - the fact that we exist means it is availble to us.
MarkSnoswell
This isn't about spinors and there is a lot more happening in this setup under different drive conditions that I dont want to discuss now...
However I thought people would be interested in this set of results that support/demonstrate longitudinal wave transmission and induction.
Oh ... and it generates a rotating magnetic field.
This is a demonstration of longitudinal wave transmission and induction between toroidal coils wound on a ferrite core.
There are three images attached:
1.   3D render of coil and core configuration. (to scale with colour coding of coils for clarity)
2.   Photograph of the oscilloscope traces from the 4 secondary coils. (labels match the 3D render)
3.   Photograph of the experimental setup. (the configuration matches 3D render).
A sine wave signal was injected into the open ended primary (orange in the 3D render) winding.
The induced signals in the secondary windings are in sequence CCW relative to the drive signal: -90 deg (blue), 0 deg (cyan), 90deg (red) and 180 deg (green).
The results are essentially the same with a square wave drive with the addition of a number of higher harmonics in the Blue and Red coils; no change in the Green coil signal and some harmonics in the Cyan coil signal.
Notes on the Experimental setup:
Core: Ferroxcube, Custom batch: 717809, Type: T140/106/25-3C90
Inner diameter 106mm, Outer diameter 140mm, height 25mm.
5 coils wound as shown in the 3D illustration (Illustration is to scale):
All coils wound from: AWG20 silver plated solid copper, Teflon insulation.
4 secondaries, 25 poloidal CCW turns spanning 90deg CCW toroidally.
1 primary, 100 poloidal CCW turns spanning 360 deg CCW toroidally.
Signal generator: HP 33120A.
Input signal: 10V PP sine @ 1,805,000 Hz.
Dr Mark Snoswell.
