EMdevices' TPU with batteries in it
Started by EMdevices, July 15, 2007, 10:33:13 AM
gn0stik
Quote from: mflynn44 on July 16, 2007, 07:44:22 PM
@EM
You?ve lost whatever small amount of credibility you had left. People should not be making excuses for you. We should just accept your situation as it truly is and continue on with our research without you.
You should reserve judgement here, really, you have no idea what you speak of, in regards to EMs character. It was  a low blow, admittedly, but he's come clean and that takes some serious cojones.
Now @EM, make with the diagrams, and hows, and with whats and all the goodies.
Justdoit
 ::)  Hi to all. I am new to this site. Concerning the toroid coil I have read that the US government dip the coil into liqiud Nitrogen. Has anyone here tried this??? Has anyone here done a toroid coil that's close to working?? ;D
Super God
Quote from: Justdoit on July 16, 2007, 09:42:43 PM
As a matter of fact, I don't believe anyone has tried the nitrogen.  But others have come close to getting some working dvices!  Quite an accomplishment!!  There are sticky threads in this forum for your reading leisure.
>9000
BEP
@Mark
Point taken on the precision control. At my current point in this exercise I am looking for a way to repeat the process with a method leaning toward mechanical design instead of controls to make up for mechanical design. While it is not easy to produce rotation by any means it appears to be far more difficult to do it with a minimum of electronics in a safe, controllable, usable and repeatable fashion, as I believe SM did with the open TPU.
I have been working a great deal on reverse engineering that one simply because it appears to use the simplest electronics and highest level of physical design. All the others seemed to require sophisticated timing and sequencing of pulses. The open TPU is a thing of beauty on the apparent methods used in layout and the simplicity of the controls I believe it used.
This is the direction I?m taking now. Most should stick with exacting controls as that will allow for adjustments to more unknowns. Also folks here have more total talent in the control side than I. I still keep a hammer on my work bench  ;)
brnbrade
