EMdevices' TPU with batteries in it
Started by EMdevices, July 15, 2007, 10:33:13 AM
EMdevices
The only TPU that has me concerned is the little one, this is a processed image which I'm posting with Lindsay's permission.
Notice the bumps on top.Ã,  Of course this one can be fake as well.Ã,  The lightbulb is frosted.Ã,  Lots of fakes can concentrate the fake in the bulb, but look to the left of it, I see a regular pattern as if there are batteries one next to the other.  Do you see what I mean?
EM
Motorcoach1
Feverishly applauding :) and i thought you put to gether a cascade cirut to feed the primary and the secondary was wound fine wire one on top of the other wind 4 different leinghts on same coil- jacketed so the BEMF pulse would not be so sharp and take the top high part of the spike ( wich in this is not really a spike ) and feed that back to the cap( battery and filter) with a blocking diode thus feeding the fets as this will keep them protected from the high volatge and not burn them out thus feeding the cascade circut and things start all over mmmmmm . who a thought :) I wasn't disapointed ,, just a good laugth  :D ;D well back to the sunshine  KISS hehehehe
kames
Hi Emdevices,
The problem with your video is that it is still not 4A as it states, even with two 60W lamps. And the major problem with your video, it is not running for half an hour, powering a TV set or a vacuum cleaner or a drill. You are not taking your tpu outside for 5 minutes and show it running again and again. Try to power you lamps as long as it works from those batteries (anyway you wasted them) and tell us the time it was working. Or, for example, try to connect it to a vacuum cleaner directly (it should work even with DC) or through a converter and tell us if it moves at all.
Anyway, well done, was expecting it.  :-X
But a torroid in the center wasn?t a joke at all.
Thanks,
Kames.
BEP
@EM
Stars??? Naaaa.... That was the VORTEX forming!
Bruce_TPU
Hey EM,
It appears to me that SM painted it with a type of resin.  This would help to secure the wirings and prevent noise from any incidental movement of the wires.  It would also assist in hardening the TPU, making it easier to handle.
It does indeed, for sure have batteries.  If you have an opportunity, please read through all of the engineering reports.  These toroids were tested for hours on end, with full loads.  They only had to be turned off because of heat issues.  Then they would be fired up again, for more hours.  It was not faked.
Then engineers are real and reputable.  And people were purposely hired to look for fraud.  All were convinced.  Ours will have batteries, and charger one day as well.  batteries are a type of control and should always remain, according to B.B.
Cheers,
Bruce
