Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
Super God
Yay, good luck Marco!!  I just tore a lawnmower engine apart out of boredom today.  I think I'll convert it to HHO since they pollute more than I car does 10 fold :o  It's amazing how much lawnmower spit out into the environment!
>9000
Super God
Perfect frequency.  Perfect sine waves.  Therein lies the secret my friend...
:D
Garbage in is garbage out!  As we programmers say!
>9000
turbo
Hi God  :)
i am running the perfect sine wave into two class A fullwave mosfet circuits which are capable of pushing 400 Watts of power at 12 volt.
this 12volt goes into two step up transformers and these put out 230 volt at a adjustable frequency.
one of these two 230 volt signals go into the plate transformer and the other goes into the heater transformer.
there is not much disortion because of the quality of the mosfet circuit aswell as it is fed with stable battery power.
Marco.
z_p_e
@All,
So in his first successful trials, we know Steven used 3 old tube type generators run through a tube amplifier.
Were these generators commercial units? Probably yes. If so, were they square wave  or sine wave generators? Perhaps they were Pulse Generators, as I believe there were a couple made in the tube days.
What kind of tube amplifier did he use? Was it a lab type, or consumer home units? Surely regardless of which, chances are pretty good they had an output transformer, which would limit the frequency response and "shape" of the pulses or square waves if that's what he was applying to the coils. There would likely be tons of overshooting and ringing.
It's quite possible Steven modified whatever amplifier he used to bypass the output transformer. This would eliminate the transformer induced problems.
These generators were also not likely synchronized, unless he specially designed something to accomplish this, but I highly doubt that.
What does that indicate to you about making catalyst?
Darren
turbo
well 3 independant sine waves with a harmonic relationship.
or better said, 3 independant rectified half sine waves....
and he probably used the tubes he had in his collection which were the vhf-rf amps.
recently someone said to hook the coils directly to the amp so i guess the output transformers were replaced by the coils.
Marco.
