Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
Grumpy
I believe Pese is saying that a spark gap or other "true switch" is required, and that FET's and other semiconductor switches will not work for production of RE.  He also says that making a tesla coil is not harder than a long-wave transmitter.
Switches, sparks (gap), relays, inductors, and / or tubes may be used to produce RE - just like Tesla illustrated many times.
        -Frank Edwards
pese
Quote from: innovation_station on September 06, 2007, 12:14:54 PM
use a fet with a spark gap ??? or a relay or ?? or??
hummm
ist
the fet as a switch (digital) spark gap  or others mentioned (mechanical)  the combo of the 2 make radient engery  controlable by ss no?
only spark gap,
you can create any voltage over 100 volt to swich on . (car spark 0,7mm have 700 volts to fire - you can "tune" them!!)
gas filled neon bulbs (control lamps 89 Volts) ore even "flash xenon lamps(bulbs)" , can be uses , but gass filled bulbs ar not so fast  as in air -or better vakuum)
you can use spark gaps as the neon , flash ore like trigger diodes (diacs) , , als to trigger them for contolled "fire points" is not the problem , if the "head" think about it.....
G.Pese
you can make cascade to create also any 100KV (inductionless , with condensor charking , to
creat an hight potential  spark  (with marx generator).
innovation_station
yes grumpy i do agree but what i was saying is that you can use a fet to control those devices and make radient engery as you wish or in the right time collect the re b4 it goes into the fet and blows it up  the fet will turn on and off your re producing switch as you need
so yes the fet will not make it on its own but can control the unit that does make it
as i understand
ist
pese
Quote from: Grumpy on September 06, 2007, 12:39:43 PM
yes , i try it to do , with my "unpolished & word-poor" english.
the voltages must only swiched , and all spikes , harmonics enz must flow (and received) FREE .(unlimited)
Not any limiting in switchtime capacitance , or clipping the voltages -in both ways - (pos & neg)
NO ONE semiconductor can this so.
Semiconductors , for normal sine and other waves to oszillate amplifier , controll Power DC - AC RF (Radio-Band)
shur is practical .  Fre eEnergy to control (IF...)  shure , must flow free over some "unknow" frequencies , or dimensions
that needs "to cach" them ... to understand .
G.P.
innovation_station
;D
well i guess it leaves only 1 way to go
tubes!!
lol!!!
a tube amp that can do 1 meg anyone got ideas?
ist
