Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
innovation_station
when 3 squares come togather at 3 diffrent freqs will we not get a nice shine with many harmonics? and kicks or spiks
that is what i see
with the beat you see above vid with a 7.8 hz gap between the 2 freq and when i add the 3rd it adds the harmonice when i add the harmonic resonance freq that is what it does it harmonizes  exploding the waves i set my harmonis freq at a high level in the 100k setting and the wave goes crazy spikes and irrulaguar static or lighting type discharges
that is how it looks on my scope i have hooked no external power to it yet to see what will happin just the freq gens
i would have shoot a vid last night but the batteries died
is
Bruce_TPU
Hey IS,
I always said all along, in my thread, that SM tuned his coil to 7.23 Hz.  Roberto and many others believe as you have been experimenting with, that this was the beat frequency.  We know that the three frequencies were VHF range.  So if he deliberately made the beat frequency between 7 to 8 Hz, one tunes into that "huge magnetic wave" as shown in Marco's dancing magnets that I spoke about so very often, also in my thread.  So, by tuning the beat frequency to the huge magnetic wave, caused by the magnetic field of the earch, would this cause the "phenomenon of magnetic collection"?  Perhaps.  Make sure your coils you are experimenting with are wound CCW and the the direction of the VHF are probably the same.  I would also suggest, since you seem serious about this, that you read Jason's latest post about what he has discovered about the different harmonics.  It will help you in your experiments, I do believe.
Cheers,
Bruce
Thaelin
@ Mannix:
   You are so right on the high voltage in tube systems. I used to have a Galaxy 550 and it had a plate v of 750v! I felt its wrath once and was very careful after that. Death is a careless touch away.
@ All
   I have over the years found myself looking back for the simple knoledge spoken in simple terms. If you have a desire to really understand tubes, I would suggest you look back into the old Ham Radio manuals. ARRL is most likely one of the best as it is geared to the amature, hence amature radio. You can find PDF's of some of the old manuals on www.pmillett.com for down load. They hold a wealth of info and are for the beginners. The 1959 manual would be a great start. It is geared towards transmitters and receivers but the very thing you are discussing here will be in the circuits use if you weed them out.
Hope that is of some help to you all.  "Tubes Live"!
thaelin
turbo
okay so today i blew up my headphones  >:( >:( >:( >:(
So i decided to build a new amp to start with  :)
Super God
Where's a good place to learn about designing tube amplifiers or amplifiers in general?
>9000
