Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
innovation_station
ok guys im sorry but you all are getting to know me now and i run my mouth a bit i love to talk and be herd thank you but it is me and has always been!!!!
so this is yet 1 more thought now dooo think hard about this!!!
2 or 3 freqs ? 2 to make the beat  other output or resonance freq to collect
basicly that is 2 or 3 channel  i think 2 channes sm says his sterio amp i the 1 quote (means 2 channel ) ok 3 channel he refers to as the 3 freq and that is center collector
basicly if we put a pluse out of the first tube in to the tpu  it comes back out of the tpu at the top and goes into another tube the siginak is then flipped so now when it comes back to the first tube but second connection or 1 connection on seconed triode tube now the siginal when it gets there is oppsite the tubes power so that is a pinch the tubes current grows  then signal and extra power are inverted agin and do the thing at the other end  and it repeats till we have resonance and good output power but we eather work with 3 seprate freqs and 2 rings and 2 channels or we work with 2 freqs the third is made on its own  and run the 2 freqs through the coil 3 times and also im starting to think this is only for the controls only and must be dc power  as per mag amp  setup and then we send posibly 5 volts ac in to center collector and use the freqs and inverted signals to control the rotation dirrection of the magfeild im starting also to wonder when steven said to cancel the flux maybe he means on the outside ring of the tpu the 15" tpu because the inside has a verry strong mag feild like a mechanical generator or altonator but spun really fast right!!
ok now do this with 3 sepreat freqs or 2 i dont know for sure yet but never the less the power will grow fast in a setup like this
like manix said it took sm 10 years to get it to work on ss and how long just to get it to work at all
also i have made no mention of feed back coils yet but have found lots about them too there just so many diffrent ways one can add power to its source on its way out to do work  hummmm  that my friend is the tesla way!!
remember the rule that says every action has a reaction well now think like tesla here  use the reaction to add to the action  thus helping to fuel its self i beleave tesla discovered that  and he used that principal in many of his inventions so that princible in the tpu use the feed back to trip the next pluse hummm but this is where i get a little iffy because it can grow way too fast and then  well humm i dont want to find out  if we do go this route lets be wise!!
is
Super God
I think I remember one of his letters saying that he first heard the the exploding TV set from his Boss in the 60's.  I think.  Those TV's were manufactured back in the 60's too I believe.  So 20 years??  Maybe.  But if we all work together we'll be able to pull this off.  I know it.  He gave us ALL the information we need to replicate it, but NO ONE is using tubes(aside from us), NO ONE is using three collectors...unless he meant something else by "three coils one on top of the other".
>9000
innovation_station
3 coils kinda like a trifller pancake coil for the 3 freqs then 1 feedback then 3 controls all on 1 ring kind of like 1 layer of my pancake coil but tuned and 1 pan cake insted of 3 stacked? if that is the case then coulld we pull 6 or 12 volts from the feed back to power the heater in the tubes so then you only need power to start it till it ramps off then power is shut off at heater of tube then feedback takes over on supply i ask this because tubes worm up and take some time to wind down after power is taken away from the heater do we could switch it from battery to feedback fairly easly kind of with out the tube really knowing or power the second heater from the feedback then we would only use half the power for 2 heaters insted of 4 plus the feedback will grow that means the heater voltage on the second triode of both  tubes will rise with ramp up a form of control i guess
well i cant wait to build this big mess i have posted if it is not right yet it is ok we are getting much closer i know it
is
well i think i draind my mind agin this time all my thoughts will stay online here last time i deleted my posts and only lost the thoughts i once had i kept no coppies so i dont even remember what i said but the last time i hit a nerve and this time im sure i hit another i say this for the this reason last time my comp went crazy getting rebooted and dissalowed macs and blocked ip's and all that stuff this time a diffrent computer my laptop and agin today the first time in a long time so i know when to read the signs
@ the watchers im done  till i play  i can see that some things have not changed  ;)
Super God
Yeah man!  One day closer!  Just a matter of time, we have all the information, now all that's left unanswered can be explained with experimentaion!
>9000
turbo
Quote from: Mannix on July 30, 2007, 07:28:47 PM
A few Tubers!...simple things really ...just bitey!
Use one only hand at all times....and it will just hurt a lot!
I have been told that a tube circuit can be attached directly to a "coil" and it will tolerate the massive harmonics generated by the interactions with out damage.
this "suggests" that no transformer was used...however, IF a transformer was used it had better be able to do 245 khz..
for some time i have been thinking he tpu is the OPT therefore we need high impedance conrol coils and the "Sound" is created inside the OPT with a low impedance secondary as output so that fit's i all.
first i am going to setup a normal situation whereas the HTR and the  OPT are synched and then i will run the HTR on a seperate supply to see what it gives when it starts to oscillate out of phase, that is easy to do for me and i should show the "verry intresting things" which can be verry revieling Steven talks about....
in the synched situation normally both circuits are running from one power supply and when you use two seperate supply's the chance of an out of phase situation increases enormous...
that is why we need two seperate controllable DC sources.
Marco.
