langley
@ Mr. Koen,
Please don't be too hard on Mr. de Wilde. The poor man has a tendency to forget to take his medicine.
Mingmei
gaby de wilde
Quote from: ltseung888 on February 17, 2008, 02:56:21 AM
Dear Gaby,
This post is for you and a few who can understand it only.
Your gold/quoted references made me realize that
(1)   One can use a downward force to move one in any direction, including upwards.  The airplane is a good example.
(2)   Most physicists thought that an external force or an external environment such friction, air etc is needed.
(3)   In reality, the Physics Laws allow an internal force from within the box.
(4)   In reality, there is no space where is no gravitation or electromagnetic field.
(5)   The Flying Saucer or the Magneto Propulsion Unit can be designed and implemented in multiple ways.
Thank you.
Keely, Tesla and Searl mention fields that make people feel fantastic.
I thought this was a note worthy trend as we also have the vastly debunked Morphic fields theory. (I personally like that theory because it works jet contradicts a lot of established dogma)
Searl and Hamel both mention building a generator that flew off the bench. (Which is the only rational reason to build a full scale prototype which they both worked at)
Respecting my own recent far fetched cosmic engine theory (as described in the publication above) in this context I thus therefrom conclude:
there are wave fields of all kinds and variations in the atmosphere.
From light to gravity, to scalars and back to electricity again.
No one is going to question this.
If one was to match up a magnetic, electric, scalar or gravitational wave it will obviously extract energy from it's environment.
Imagine standing on a podium that moves up and down 10 cm every 2 seconds. Now you are going to jump up and down. It would make sense to jump when the floor is at it's highest point. If you would jump with 0.4 hz you slowly phase out of sink with the floor. Eventually you would be trying to jump while the floor is moving downwards.
The reason we have tides is not because the gravity of the moon is pulling the water up.
That wave has been there ever since day one!
Normally waves smoothen out because of earths gravity.
But if the water is moving in the direction of the moon with the speed of the moon Earth's gravity is going to have mighty trouble slowing it down.
The better the speed of the moon is matched the more it appears to be dragged along with it.
But it isn't quite dragged along you see, that wave is the product of millions of flyovers not just one.
The wave is a million years old, terrestrial Gravity cant stop it because of lunar gravity.
David Hamel showed the world that if you position a sharp stick exactly vertical, that is 90 degrees perpendicular to the earth. Then the stick tips over. What can I say? It doesn't even happen slowly, the stick starts it's drop almost instantaneously.
If it drops into a repulsive magnetic field it may reverse it's direction and do the same at the other end.
If however we can set the frequency of the tumbler it should be possible to match the wave that initially pushed the stick over. In theory at least, in reality you would end up dialing like mad not knowing what you are looking for.
Hamel however stacked cones one on top of another!
That allowed his devices to oscillate at variable speed!
The first push gets it going, the second push tunes the frequency.
The part of the machine moving at the right frequency will not cooperate with speed changes with the same ease as the parts that are just swinging around at other frequencies.
Matching the frequency is hard (specially more then one at a time) but when it's tuned in it should tend to stay there.
Like the 2 metronome's entraining another.
http://www.youtube.com/watch?v=yysnkY4WHyM
And when you match special fields the humans standing next to it start to feel good.
And I thought astrology was to far-fetched.
HA - what do I know right?
lolzzz
blog  | papers | tech | inventors  | video
gaby de wilde
Cool I explain astrology, homeopathy, the ?ther, morphic fields, radionics and the chakras/chi etc in one post. hahaha
Here Mr Tseung, you liked my cyber alchemy so I made this for your forum.
http://forum.go-here.nl
It almost hurts from laughter?
Top Gun
Dear Mr. Tseung,
I did a google search on the theory of the Flying Saucer and got over 50,000 hits.  I glanced over some of them.  So far, I have not found a single one that can explain the physics of the Flying Saucer to my satisfaction.
Your Lee-Tseung Lead Out Theory started from:
(1) We are immersed in gravitational and/or electron motions fields.  If we can use such energy, we do not violate the Law of Conservation of Energy.
(2) A Pulsed Pendulum Leading Out gravitational energy
(3) A Pulsed Magnetic Pendulum Leading Out electron motion energy
(4) An unbalanced wheel is effectively a pulsed pendulum
(5) A pulsed balanced wheel has the similar effect as (2) but much more efficient
(6) The Newman, Bedini, Adams, 225 HP, Liang, Chao etc. inventions are essentially variations of (4) or (5).
(7) The Forever flying bottle experiment or the two balls hitting the two sides (one padded) of the silly spaceship scenario pointed to the possibility of producing thrust internally without the need to eject hot gases.  There is no violation of Newton's Third Law.
(8 ) The sketch in 1165 combines the Cosmic Energy Machine in (6) and the elements of (7) to produce the Flying Saucer.
Your total step-by-step theoretical approach is intriguing.  Every step obeys the known and existing Laws of Physics.  If we accept the use of parallelogram of forces in step (2), the rest are simple.  Omitting or non-acceptance of that step will create non-believers.  You and Lee might be elevated to a previously undreamed of status in Science.
My eleventh question is:
(11) Have you presented your total theory with the above outlined 8 steps to any established academic institutions yet?  If so, what are their reactions?
Devil
Quote from: Top Gun on February 18, 2008, 03:30:41 AM
Tseung, do not be misled by praises from Top Gun.  The jealousy I planted in the minds of men will stop all fame and fortune going in your direction.  No Westerner will ever accept two Chinese retirees can revolutionize Western Science.  They will say that some Westerners (e.g. Joseph Newman) already discovered the Cosmic Energy Machine.  Prof. John Searl and David Hamel already produced the Flying Saucer.
The Russians may quote Milkovic.  The Japanese may quote Minato.  You do not stand a chance ? except within China.  Even in China, they may quote Wang, Liang and Chao. The Physics is simple.  The Politics is not.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
