0 Members and 46 Guests are viewing this topic.
jeffc
Quote from: Forever on August 20, 2007, 03:04:47 AM
Here is my layman 's translation of the second page of the Liang patent.   ;D ;D
Also, thank you for your interpretation, which is helpful.  If someone could figure out what the ICs are and how they interact then perhaps this could be replicated.
Regards,
jeffc
jeffc
Quote from: Humbugger on August 20, 2007, 02:30:19 PM
Quote from: Iosh on August 20, 2007, 01:51:03 PM
Quote from: Humbugger on August 19, 2007, 09:53:38 PM
Quote from: Iosh on August 19, 2007, 09:29:58 PM
Well, if I understood it correctly, Lawrence basically says those so-called ICs are just reprogrammable magnetic chips.
Searching "magnetic chip" at Google gives a fair amount of related results.
I chased the first three pages worth...most are talking about mechanical conveyor belts to move chips of ferrous material, a few are about magnetic bubble chip memories.  None seem to say anything about an IC chip which simulates or behaves like a magnet where the external fields are programmable.
I suppose any chip inductor would do this, but that's just a common (if tiny) electromagnet, not an IC and certainly not an Intelligent Chip.  nice try...no cigar!
Wouldn't those IC chips be a stripped down version of the magnetoresistive memory microchips? http://www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=015424&tid=FSH
No.  The Freescale devices are, like all magnetic memory chips, nano-gauss devices whose field strengths involve orders of magnitude lower numbers than the weakest, wimpiest, tiniest refrigerator magnet known to mankind.  They are not in any way capable of or intended for creating motion-inducing external fields; in fact they are internally shielded to prevent even weak external fields from upsetting their content.
I believe that Mr. Tseung and Ms. Forever, and maybe the inventor, Mr. Liang, are not truly atempting to give out any genuine information about real inventions, sad to say.  I am open to any hard data or logical explanations, but all I hear so far is charming stories and wild technical claims...nothing at all specific or explanatory about these world-beating inventions.
If these inventions are real to any degree, there has been no evidence presented yet, in my opinion, despite the many requests.  The Chinese patents, even when so graciously translated by the lovely and talented Ms. Forever Yuen, add nothing to further understanding...only more outrageous and seemingly-nonsensical claims.  It is hard to imagine those documents as protective of intellectual property, since they disclose none that I can detect.  Lots of undefined terms; no substance.
@Humbugger
I absolutely agree that this patent would not fly in the US or Europe.  The very purpose of a patent document, by definition, is that the invention can be easilly reproduced by someone with experience ("skill in the art") by following precise instructions.  It is not supposed to be a guessing game.
That being said, the quality of the patent document doesn't provide any conslusions about the invention itself, only a glimps into differences in the western and Chinese patent process.  IF the US patent office would grant me a patent with this level of detail, I would have done it as well!
Regards,
jeffc
Iosh
Quote from: jeffc on August 20, 2007, 08:05:09 PM
Well, those seem to be nothing else than... electromagnets with memory of their magnetic state? How can such a simple device have not been invented yet? :P
Saving the differences with the MRAM, the concept seems to be the same. The question is how much power would require such an useable magnet to change its polarity.
Humbugger
Quote from: Iosh on August 20, 2007, 08:43:34 PM
Dat's da question, all right!  And how would you create a high-gauss magnetic field of any orientation using only a tiny ultra-low power IC chip?  Those are the questions on the table here.  I await any good answers from our experts!
ltseung888
Dear Forever,
Thank you for your translating the first two pages.  I am specially impressed with your interpretation of the second page reproduced below.
My (Forever Yuen) interpretation
There can be two cylinders. The inner cylinder can rotate and has one type of intelligent chips. It is also connected to the rotating axle. The outer cylinder does not rotate and contains another type of intelligent chips. ( In a later part of the patent, the two types of chips are refer to as China 3001 and China 3008) These chips are programmed to provide a pulse rotation.
Since the magnetic interaction is very small between two ICs. A large number of ICs are used. They are placed very close to each other.  Assume the magnetic interaction force between ICs is ?X?. Assume the total number of chips of one type is ?N?. Assume the rate of rotation is ?R?. If the diameter of the cylinder is ?D?. The energy is related to D times X times N times R. If typical value N= 700, R = 100 revolution per second, D= 0.5 meter . The total energy would be related to 35,000 times X. Even if the lead out energy is 50% of this amount, that energy is very significant.
This is the reason why a 188 horse power engine can be produced.
Please comment.
There are two comments I would like to make.  The first one is that the r=100 per second may be too high.  (6000 rpm).  I believe the more correct understanding is that r= 10 per second.  However, each IC may react with 10 other ICs in 1 revolution (If the 700 ICs are arranged in 10 rows).  The resulting number is still 100.
The second comment is that there are at least two more factors involved.  One is the mass of the rotating cylinder.  The other is the gravitational constant g.  The gravitational constant g can effectively be changed with your magnetic pendulum type setup.
Many chip experts know how to program the Hall Effect ICs and/or Magnetic ICs.  (I am NOT one of them.) However, few of those I know have ever thought about programming them to provide power.  They all wrongly applied the Law of Conservation of Energy.  They thought it would be pointless to use ICs to rotate the axle.  The energy loss and complications would not justify the effort.
The Tsing Hua University Professors and Students are the exceptions.  They believed in the Lee-Tseung Lead Out theory after a half day explanation by Lee-Tseung-Wang.
I shall wait for you to finish translating more pages before additional comments.  Please keep up the good work.
Lawrence
