Pirate88179
gaby de wilde
There are ideas enough, there is a problem with finding people who can do something with the ideas.
Here, i posted this earlier, technically this should fix all energy problems.
http://groups.google.com/group/sci.physics/browse_frm/thread/e1470b6e2c571730
Hemp plasma reactor - sci.physics | Google Groups
Even if a person wants to pretend there isn't enough data then that absolutely doesn't mean it doesn't work. It means "pretending there isn't enough information available" and that is what it means.
Anyone who tries to create an absolute truth or an absolute mistake is always wrong if there is not enough information available.
Not enough information can only mean we should be looking for more data. It can never be an excuse not to gather data.
"I don't know enough about this now I do not have to look deeper into this as this proves it doesn't work!"
The plasma reactor seems to be well documented by now.
Pantone seems to have disappeared into US bureaucracy but the reproductions in France also seem to be a hobby effort.
Officially the whole thing only exists as the Plasmatron  MIT invention. haha?
And hemp = danger danger?? haha?
Depending on the soil there are probably a lot of other crops that could supply oil + something else. The remaining wood pulp can be used to make paper and to power big generators.
http://quanthomme.free.fr/qhsuite/cam4man6x6.htm
Quote" Bonjour,
Voici en annexe les photos du montage Pantone install? sur notre camion 6x6.
Nous remercions notre ami Herv? Fargeix qui nous a fabriqu? les r?acteurs et donn? de pr?cieux conseils pour la fabrication du bulleur et du montage en g?n?ral.
Nous habitons en Belgique et aimerions conna?tre d?autres Belges travaillant sur le syst?me Pantone."
QuotePaul Pantone's GEET Device Explained in Full Detail. For everyone that doesn't understand that this is a fine tuned device. Just because some people failed building it, doesn't mean there hasn't been successful attempts at making this device work.
There is a exact science behind this device! The people who failed, failed because of their own wrong doing.
Devices Fitted Successfully:http://64.233.179.104/translate_c?hl=en&langpair=fr%7Cen&u=http://quanthomme.free.fr/qhsuite/Real2007SystPantone.htm
http://translate.google.com/translate?u=http%3A%2F%2Fperso.orange.fr%2Fquanthommesuite%2FRealPMCPantone.htm&langpair=fr%7Cen&hl=en&ie=UTF8
http://translate.google.com/translate?u=http%3A%2F%2Fperso.orange.fr%2Fquanthommesuite%2FReal2006SystPantone.htm&langpair=fr%7Cen&hl=en&ie=UTF8
Description of Device Operation:
Plasma Fuel Reforming with PMC (Processing Multi-Carbons)
The bubbler is a tank containing a mixture of water and hydrocarbons (gasoline, diesel, kerosene, crude oils and others derived from hydrocarbons...).
The hot gas flow coming from the exhaust of the engine circulates by the outside part of the reactor with a strong kinetic energy, that contributes to bring up to very high temperature the steel rod (being used as heat accumulator) contained in the pyrolytic chamber. The gases cross the engine and penetrate then in the bubbler containing the water/hydrocarbon mixture. The vapor of the mixture is strongly aspired by the vacuum created by the engine intake and is pushed by the pressure coming from the exhaust. The kinetic energy of the vapor is increased considerably by the reduction of the diameter in the pyrolytic chamber (by Venturi effect). The combined effect of the high temperature and the increase of the kinetic energy produces a thermo chemical decomposition ( molecular breakdown ) of the water/hydrocarbon mixture.
The endothermic reactor forms an Electro-Plasma-Chemical unit (EPC) and it is now possible to create a high-output fuel coming from the decomposition of the water contained in the water/hydrocarbon mixture. This fact is confirmed by the presence of oxygen gas (O2) in great amount measured in the exhaust.
More information:
At the Massachusetts Institute of Technology (MIT), researchers are developing a reformer, which, like the KCB&H one, uses plasma for reforming hydrocarbons. The advantage of a plasma reformer is that it can use all forms of hydrocarbons, including heavy oil fractions. In addition, the plasma reforming can operate in pyrolytic mode (thermal degrading of organic material without air or oxygen) so that the carbon is turned into soot. This eliminates the formation of CO2. Plasma technology allows for a more compact and lighter design than traditional reformers because the reaction occurs much faster. (BingoFuel Reactor)
The plasma reactors can be placed by the road and send wireless electricity to the electric cars driving by.
If energy can be transmitted efficiently we can get hundreds of miles to the gallon. Use a small capacitor bank to drive from charging station to charging station. Sure one would have to stay within range of the main road to be able to drive such car.  The point is that it would be dirt cheap to move the vehicle if it didn't have a combustion engine or heaps of batteries in ballast.  By running the engine at it's ideal speed it becomes much more efficient then when driving around with it. And cold starts are also avoided .Construction can be much lighter and much safer.
blog  | papers | tech | inventors  | video
Localjoe
@Gabby
You made bill take down a picture that you use for an avatar in another Fourm? That makes sense.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
gaby de wilde
Pirate88179
@ Gaby:
With all due respect, it sounds as if you are jealous of not being an American.  You attempt to put us down every chance you get and this has nothing to do with over unity either.  I know where you live, and that's fine.  Stay there.  You would not make a good American.  Freedom is something we have and you don't, and don't even know what you are missing.  Talk about ignorance.  You can bash me all you want...feel free to do so, but do NOT bash my country.  If not for us Americans, you would be speaking German right now.  So, let's talk about science, ok?
