Cap-Z-ro
I think Lawrence wood be able to find logic in ice cream. :)
Despite herculean efforts to find one, there appears to be no corners in the world of Lawrence Tsung...at least none that will be revealed in this venue anyway.
At the very very least I am still thoroughly entertained.:)
Regards...
chrisC
Quote from: ltseung888 on March 12, 2008, 04:15:50 PM
It also confirms the inertia propulsion technology as discussed in relationship to the Flying Saucer.  There is no need to eject hot gases for propulsion.
I do agree with this statement Mr. Tseung. The only hot gas ejected seemed to come from your posterior! Time and time again in these past
cheers
chrisC
shruggedatlas
Quote from: ltseung888 on March 12, 2008, 04:40:56 PM
Do not stand on the scale.  Jump and compare the maximum deflection of the needle with and without the pillow.  Do not remain on top of the scale.
Sadly, the little balls in your perpetual motion machine do not have the option to jump off.
ltseung888
Quote from: shruggedatlas on March 12, 2008, 08:34:24 PM
The top balls jump/bang on hard surface.  The bottom balls jump/bang on padded soft surface.  That fact cannot be denied.  The Laws of Physics (force = rate of change of momentum) demands a net downward force/torque.
The continued experiments include:
(1) different padding
(2) different falling height
(3) different diameter of wheel
(4) different weight of wheel or attaching different weights to rim
(5) different speed of rotation
(6) addition of different load to change friction
(7) different size balls
(8) different number of tubes
(9) different angle of the tubes
Such comprehensive experiments will take time.  Hopefully, the balls will not jump out.
Devil
Important Proof of Concept Experiment by Mr. T.S. Cheung 張天松 in March 2008
Tseung, do you realize that the Cheung suggestion is worth a patent.  If the experiments really worked (as indicated by the Bessler wheel), the invention could be worth millions.  The Physics is a piece of cake.  The explanation is obvious even to non-physicists.
Your team of supporters will blame you on ruining their chances of becoming millionaires.  They may not disclose their findings to you again.
The experiments are simple enough to be done by even primary school kids.  Are you trying to use the Bedini School Girl Motor model?
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
