0 Members and 27 Guests are viewing this topic.
Devil
Quote from: utilitarian on July 18, 2008, 08:54:58 AM
Say there are gravity motors all over the world creating free electrical energy, which is used to light up city streets and is ultimately escaping to outer space as light.
Over time, will this weaken the gravitational forces between the Earth and the various moving parts of the motors?  This is a very simple question.  Yes or no?
Stupid humans, why do you have to add absolutely unsound assumptions such as "ultimately escaping to outer space as light".
The creation of electricity from the gravitational lead-out-energy machines can be used within Earth as manufactured products, houses, cars, flying saucers etc.  They do not need to "ultimately escaping to outer space as light."
CoE only applies to a closed system in the first place.  A closed system is one where we can identify the exact total energy input and output.  There will be no other energy coming and leaving the closed system during the consideration.
In reality, gravitational (and electronic motion or magnetic) energy comes and leaves any system in the universe.   An absolutely closed system does not exist in this universe.  The CoE is a convenient way for scientists and engineers to design the traditional fossile fuel machines.
With lead-out-energy machines, CoE must be looked at in the new light.
How stupid humans are?  They treat CoE as an infallable Bible.  They take it not as a Law to follow but as Faith not to be questioned.
Wake up.  Stupid Humans.  Physical Laws have their limitations.  Beyond the limitations, they break down.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
utilitarian
Quote from: Devil on July 18, 2008, 04:14:01 PM
Don't latch on to minor points to dodge the question.  In the case of streetlamps and other outdoor lights, yes, indeed some of the light escapes to outer space.  Sure, other light could be recaptured somehow, and certainly gravity motors could be used for more than streetlamps.
But please give us a straight answer.  Suppose that there were millions of gravity motors set up, powering floodlights pointed at the sky, allowing light to escape earth and into outer space.  Would the gravitational force between the earth and the moving parts of the gravity motors eventually be reduced to nothing?  If not, then you have violated CoE.  What do you say to such a simple question?  Surely you can answer it.
Devil
Quote from: utilitarian on July 18, 2008, 08:45:00 PM
Stupid humans, have you heard of E=M*C*C.  The actual energy in terms of mass that can be sent to outer space by your floodlights is minimal.  A couple of flying saucers leaving earth will carry much more mass than that.
Your stupid question is like - if we keep sending flying saucers to outer space, will the mass of the Earth eventually become zero?
Obviously, if there were flying saucers returning to Earth or if we have alient visitors, the equation may balance out.
Now you remember that mass and energy can be converted to each other.  If you can somehow reduce the mass of the Earth to zero, you will deplete all gravitational energy.  So long as the mass of the Earth remains more or less the same, there will be no running out of gravitational energy.
utilitarian
Quote from: Devil on July 18, 2008, 09:20:34 PM
So are you saying that each individual gravity motor, when running, depletes the Earth's mass a little bit?  If so, how exactly is this happening?  Yes, we know that mass can turn to energy, but how does a swinging pendulum, with Lee-Tseung pulls, convert some of the earth to energy?  The bob is not even in contact with the ground.  I do not see any fission or other chemical changes going on with the swinging pendulum.
Please explain this facet of your theory to us mere mortals, because I do not follow.
Devil
Quote from: utilitarian on July 18, 2008, 10:13:45 PM
Stupid Mortals, I did not say that the pulled pendulum would convert mass into energy.
The pulled pendulum will increase tension of the string.  The vertical component of the tension time the vertical displacement equals work done in the vertical direction by the string.
The string itself does not have energy.  The energy comes from gravity.
Recite the above 666 times before you post again.
